Aug 23, 2019 at 1:35 PM
(Merged)
loses power going up hill and jerks on hills sometimes
1999 BUICK REGAL
THANK YOU
buick 1995 after 5 minutes i am runing the car the check engine ligt come on and the car shut dowm lose power have to wait 2 minute the car turn on but keep ligth chekc engine on and car dosnt run good ? the 2 sensor were replaice the crams and the other
(Merged)
Check applicable codes. If your fully obd1 compliant, you can check codes yourself. How long since a tune-up? Any electrical sensor, if there is a problem on the wiring circuit, replacing the sensor won't fix it. Also, you could disable the fuel system, use a spark tester on each plug wire, one at a time, engine cranking, see if you have spark at all plugs. If you have spark everywhere, use a gage and check fuel pressure.
(Merged)
Engine Performance problem
1997 Buick Regal 6 cyl Front Wheel Drive
My Buick is running real sluggish when accelotating and on inclines any advice?
(Merged)
i would consider checking the ignition timing and try putting in a higher octane gas, let me know how that goes, post back.
(Merged)
