Jan 22, 2021 at 1:16 PM
(Merged)
Fuel Filter Location?
2007 KIA OPTIMA
check fuel pressure and scan for codes and check fuses underhood. it also may be the anti theft so try resetting it. if you don'thave amanual look online.
Thanks and Ride Safe.
(Merged)
Engine Performance problem 4 cyl Two Wheel Drive Automatic 141000 miles
I can't find the fuel filter. It is a canister type with threaded fittings on each end. Can you tell me where it is. I have looked undcer neath the car and on the firewall. Can't locate it...
Thanks!!
Thanks!!
(Merged)
should be under car near fuel tank, easiest way to find is just trace fuel lines. Here is a guide to show you what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
(Merged)
