Engine overheating
1995 HONDA CIVIC
LEHELLCAT
Engine Cooling problem
1995 Honda Civic 4 cyl Front Wheel Drive Automatic 170,00 miles
i ran over a quite a few large rocks. busted a hole in the tranny casing in my honda civic 95 lx. anyway my brother dropped the transmission out and put a new one in. but now the fan is not working right and is overheating the car. he has hooked it to the battery and then it works fine. could i have knocked something loose? where should we start looking?
Feb 8, 2018 at 1:03 PM (Merged)
F4I_GUY
  • 3,302 POSTS
Check the operation of the fan switch located on the thermostat housing (a 2 pin harness connector) That is most likely your problem with regards to the fan problem.
NATALEE
1995 Honda Civic
I have a real big problem, i pour coolant in my car last friday however today i notice that where i park was full of coolant that came from my car i dint thinkl anything of it been that i dont know much about cars, a little later while driving home i realised that the temp. gauge was on "H", is this serious will i no longer have a car to drive?
MHPAUTOS
  • 31,937 POSTS
Hi there,
you will need to get the coolant topped up and get to a mechanic that can do a cooling system pressure test, this will locate any external coolant leaks, hopefully you have done no damage and it can be fixed quickly.
mark (mhpautos)
RAIMIER
1995 Honda Civic 4 cyl Front Wheel Drive Automatic 83000 miles
my coolant is going into the overflow tank even when the engine is not hot but it stays there and does not return to the radiator. I have a new thermostat and water pump, no apparent leaks, what could be the problem
MHPAUTOS
  • 31,937 POSTS
Hi there,
get the pressure cap tested, or just replace it as i feel that this will be your problem.
Mark (mhpautos)
TEDLA
Engine problem
1995 Honda Civic Engine Size unknown Two Wheel Drive Manual 100000 miles
how do i solve over heating of engine and failer of the cooling system?
MHPAUTOS
  • 31,937 POSTS
With out knowing more details the first thing to check is Coolant loss, Cooling fan operation, Thermostat operation, Radiator radiator cap water pump.
If you give more infomation as to your concerns i will try and advise.
Mark (mhpautos)
