To begin yes my car really has 9500 miles its been sitting for about 7 some years and im trying to get it running again and the problem im having is that i had the car running and the main battery fuse the 100A inside the engine compartment went out and ever since that ive been having problems with the alternator so i when ahead a bought a new one and its not charging and the battery light in the speedometer doesnt shut of but the light looks a little faded compared to the rest of the lights in the speedometer. Then i hooked a scanner to it and it only comes out with a transmission code which was fauty solenoid b which im still trying to fix. Then my other problem is that i unhooked alot of different plugs to see if anything came out in the scanner and nothing, no codes, so i changed the ECU thinking that was it because the main 2 wires that come from the alternator go to the ecu and its still the same. I also bought all 3 of the fuse boxes and its still the same no signal for the engine and ive almost gotten to the point to were im going to buy a new engine harness to see if thats it but i really dont want to because its expensive. So as you can see i need help badly so any help would be appreciated thanks.
Jun 28, 2010 at 4:20 PM
