[quote:6a0398f832="phantom241"]Engine Cooling problem
1997 Honda Accord 4 cyl Automatic 187245 miles
I have a 1997 Honda Accord, 4cylinder, automatic transmission. I try to keep it in good condition, oil check every 3k , and tune up every 50k. However, last week, after driving for an hour on the freeway, i notice the engine temp started to rise slowly to the red zone. I parked it and notice coolant was leaking from the engine and the water tank was empty. Towed it to a mechanic, the mechanic replace the top hose (he called it the "big" hose connecting the engine to the radiator). Filled it with coolant , tested the fans, and said it was good to go. The next day, i drove it and the tempurature started to rise again. I opened the hood and check the coolant level, and it was fine. I notice however that when i leave the car in idle, the RPM would go up by itself w/o stepping on the gas, and slowly after that the engine tempurature would rise. I read some forums and saw that it could be a water pump issue. 1) is it a water pump issue? 2) other hose need to be replaced?
Note: I can hear the fan running after i shut off the engine. 3) Should i be concern about the radiator fan?
I just want to be sure i know my exact problem is so that i wont get ripped off by another mechanic.
Please help !!
Kenneth[/quote:6a0398f832]
The over heating could be the Thermostat. When was it last check or changed?
The increase in RPM's - is the check engine light on? It could possibly be the Throttle Position Sensor or a vacuum leak.
The fan continueing to run when vehicle is shut off is normal. The engine will increase in temp 10 - 20 degrees before starting to cool down so the fans stays running to help cool the engine down quicker.
Dec 18, 2019 at 9:58 AM
(Merged)
