ran it a second time
same things happened upon start up.
Here is the diagnostic readout
DTC Information
Stored Codes
P0300 Multiple Cylinder Misfire Detected
P0405 EGR Position Sensor Circuit Low Input
P0418 Secondary Air Injection System Relay A Control Circuit
Pending Codes
Diagnostic Information
Freeze Frame Information
Parameter Description Value
DTC for which Freeze Frame was Stored P0300
Fuel System 1 Status Open Loop
Fuel System 2 Status Open Loop
Calculated LOAD Value 12.94 %
Engine Coolant Temp 150.80 °F
Short Term Fuel Trim - Bank 1 0.00 %
Long Term Fuel Trim - Bank 1 -1.56 %
Short Term Fuel Trim - Bank 2 0.00 %
Long Term Fuel Trim - Bank 2 -0.78 %
Intake Manifold Absolute Pressure 15.99 inHg
Engine RPM 1,347.00 rpm
Vehicle Speed Sensor 1.24 mph
Air Flow Rate Mass Air Flow Sensor 2.93 lb/min
Absolute Throttle Position 7.84 %
Monitor Information
Monitor Name Monitor Icon Status
MIL ON
Misfire Monitoring Complete
Fuel System Monitoring Complete
Comprehensive Component Monitoring Complete
Catalyst Monitoring Not complete
Heated Catalyst Monitoring Not Supported
Evaporative System Monitoring Not complete
Secondary Air System Monitoring Not complete
A/C System Refrigerant Monitoring Not Supported
Oxygen Sensor Monitoring Not complete
Oxygen Sensor Heater Monitoring Not complete
EGR System Monitoring Complete
Mar 15, 2009 at 9:07 PM
