Swap Engine
2004 FORD RANGER
108,564 MILES • 4 CYL • 4WD • MANUAL
MASTERTECHTIM
  • 4,750 POSTS
leave transmission in car. if installing standard on a engine that had a automatic the only thing you have to do is use the flywheel from the standard motor and you will have to install a pilot bearing into the crankshaft of the new engine. hope this helps
Jan 13, 2020 at 10:53 AM (Merged)
JASON SNYDER
It looks like there haven't been any changes to the block from 1993 to 2002?
Thanks!
Jan 13, 2020 at 10:54 AM (Merged)
Good afternoon,
Correct. The basic blocks are the same. It is the add ons that are different for each application.
