fuel pump replacement
1995 FORD RANGER
92,000 MILES • 6 CYL • 4WD • MANUAL
M PATTEN
I took the straps off, need to know what else to do to take tank out.
Mar 31, 2009 at 12:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL:
Disconnect the negative battery cable and relieve the fuel system pressure.
Siphon or pump as much fuel as possible out through the fuel filler pipe.
Fuel injected vehicles have reservoirs inside the fuel tank to maintain fuel near the fuel pick-up during cornering or low-fuel operation. These reservoirs could block siphon hoses or tubes from reaching the bottom of the fuel tank. Repeated attempts, using different hose orientations, can overcome this obstacle.
Raise and safely support the vehicle.
If equipped, remove the skid plate attaching bolts, then lower the plate and remove it.
On Explorer/Mountaineer models, the front fuel tank strap is bolted to the skid plate and will be disconnected when the plate is removed.
Disconnect the fuel fill and vent hoses connecting the filler pipe to the tank.
On vehicles equipped with a metal retainer fastening the filler pipe to the fuel tank, remove the screw holding the retainer to the fuel tank flange.
Disengage the fuel lines and the electrical connections to the fuel tank sending unit/fuel pump assembly. On some vehicles, these are inaccessible on top of the tank. In this case, they must be disconnected when the tank is partially lowered.
Place a safety support (such as a floor jack) under the fuel tank and remove the bolts from the fuel tank straps. Allow the straps to swing out of the way. Be careful not to deform the fuel tank.
On Ranger vehicles, the rear fuel tank strap has two connections which must be unbolted.
Lower the tank a few inches, then detach the fuel lines and electrical connection from the sending unit/fuel pump assembly, if required.
Remove the tank from the vehicle.
Thanks for using 2CarPros.com!
Mar 31, 2009 at 12:58 PM
LAPDOG
What are the steps to replacing a fuel pump on a 1995 ford ranger XLT, 2.3 liter, and specifically about disconnecting the gas tank and reconnecting it? I have never done an in tank fuel pump replacement before.
Thanks for your help!!
Lapdog :D
Sep 16, 2019 at 8:57 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
First needs to be as empty as possible. You will need special release tools to get the fuel lines off the tank unit.I would suggest you have some help under there unless you plan on unbolting the bed and moving it back (have seen people do this) I also recommend using a factory pump, replacing the relay and filter at the same time
JMENDOZA619
  • 4 POSTS
My ranger broke down on me today, I thought it might of been that i ran out of gas but I didn't. The tow truck drive thinks it might be the fuel pump, Im hoping its the fuel filter. I really can't afford to replace a fuel pump. Would you be able to tell me where I can find the fuel filter In my 1995 Ford Ranger? also any other info you might think I might need?
Thanks For your help....
BLUELIGHTNIN6
  • 16,542 POSTS
Fuel filter is under vehicle, driver side, below seating area, mounted on frame in fuel line. Can you hear fuel pump come on when first turning ignition?
JMENDOZA619
  • 4 POSTS
Yes it does... I changed the fuel filter and relay. The engine is getting gas. But it still won't start. Any idea's?????
BLUELIGHTNIN6
  • 16,542 POSTS
is it cranking at all? check for healthy spark at plugs
JMENDOZA619
  • 4 POSTS
I want to say yes. It sounds like it want to start, but something is not letting it. I hope you can understand what I'm talking about. There is power, everything turns on when i turn the key. The needles on the dash board all move exept the oil that needle is all the way to the bottom. Thanks for yor help.....
BLUELIGHTNIN6
  • 16,542 POSTS
okay so when turning the key the engine makes noise like its starting? or do you just hear a click noise?
PORTNOYKID
1995 Ford Ranger 4 cyl Two Wheel Drive Manual
is there a place online i can find step by step instructions on how to change my fuel pump or how do you do it?
MERLIN2021
  • 17,250 POSTS
First, drop the gas tank, unplug the connections, use a spanner wrench to remove the lock ring, or a hammer and BRASS punch. Pull out the old pump, dissconnect the wires, noting where the go, install new pump...reinstal lock ring, plug in the connector, install the tank! Try to remove all but about 1 gallon of gas, or the tank will be HEAVY!
JMENDOZA619
  • 4 POSTS
YES, it sounds like it wants to start....
BLUELIGHTNIN6
  • 16,542 POSTS
will need to test for proper fuel pressure and good spark. if both OK check compression in cylinders. if compression is low then check for a broken timing belt.
RICH211
do i have to drop the fuel tank to replace the pump ? and how do i test the pump relay ? thanks" rich"
CAMERON TARTER
unfortunatly yes tank must be droped to replace pump !! i may have to do this to mine as well . icant figure otu why it keeps dying on me !! as for the relay i would like to know as well !!
DOC08TN
  • 5 POSTS
I have replaced the fuel pump and have 40 lbs at the rail. I have also checked all fuses and I have a good injector pulse.The truck ran great untill it sat up for about a year.It will fire right up with a shot of ether, but dies immediately after the ether is gone.It is a 3.0 with a distributor.
HMAC300
  • 48,601 POSTS
check your fuel pressure, sounds like you don't have any
DOC08TN
  • 5 POSTS
As I stated in my original question, I have 40 lbs pressure at the fuel rail.
HMAC300
  • 48,601 POSTS
if it's not getting fuel it can be the eec could be bad or it could be a ground going to it. so clean your groundsit shold be a black wire. there also is a eec power relay and that could not be letting the eec power up so check that as well......
DOC08TN
  • 5 POSTS
I have a good injector pulse.Would I have the injector pulse if the eec or its ground was bad? Also if the relay was out would I still have injector pulse?
HMAC300
  • 48,601 POSTS
if you have an injector pulse then you probbly have an injector problem. butyou would need good pulses at all of them and they need to be tested with a noid light.
JONATHONMCDUFFIE
Will a 2004/5/6 Escape fuel pump fit a 94 Ranger
KHLOW2008
  • 41,814 POSTS
Most fuel pumps are generic but I am not sure if the pump would fit. The only way to find out is to remove and compare them visually.
You can check with the junk yards, they should be able to tell you.
DOC08TN
  • 5 POSTS
I have only checked one injector with a light for pulse, the easiest one to get at. What would be my next move if I get a good pulse from all six injectors? Would one or two bad injectors stop the engine from at least trying to start?
WRENCHTECH
  • 20,761 POSTS
No, they will not work. they are quite different. The later models use a module controlled, variable pressure pump system.
HMAC300
  • 48,601 POSTS
wellyou could have a rich or lean conditions when they stop.i am assuming you have already checked this vehicle for codes as this may be the cause as well if this has anti theft and it has locked the system. that needs to be checked out as well.
KHLOW2008
  • 41,814 POSTS
Thanks for the info.
DOC08TN
  • 5 POSTS
Yes I have scanned the vehicle and there are no codes except all systems pass code. This vehicle has no anti-theft system. So if I do get a good pulse at all injectors what do you suggest I look at next? I thank you for your prompt replies and your patience.
HMAC300
  • 48,601 POSTS
i really dont' know what to do, if youa re getting apulse thene the injectors should work unelss theyare all bad and i kind of doubt that. not having it to look at all i can suggest is to check resistance in injectors. otherwise have apro look at it.
SEROBINSON
after replacing fuel pump, plug wires,sprak plugs, and coil. Engine turns but won't start.
98RANGERXLT
  • 301 POSTS
Check all connections make sure theyre clean and tight if thats not it maybe your battery
TERRILKIRK
Could it be the solenoid?
TERRILKIRK
connections was it!!
Thank you
SEROBINSON
after replacing fuel pump spark plugs,wiresand coil truck will turn but not start. Truck was running just fine after replacement of above items. sat overnight went to start next morning and would not
MRBLOODGOOD
My truck sometimes wants to rev up to 3000rpm while driving. Never when stopped. If i push the clucth it will rev high to 3000 and when i release clutch i can feel the truck pulling itself without me adding fuel. I have replaced fuel pump. Filter. Iac. Tps. Relays. I even did a warranty swap on the iac and tps to see i had gottwn faulty ones. Still same issue.
MRBLOODGOOD
I would also like to note i have replaced all vaccum lines. I did a self smoke test and also sprayed ether and carb cleaner at all spots it may be leaking from. No leqk found
HMAC300
  • 48,601 POSTS
clean throttle plate on both sides and iac hole with choke cleaner then scan for codes.
DRERY
My truck is sputtering as soon as I try to give it gas. I have changed all of the filters, replaced fuel pump, fuel filter, spark plugs, and new battery. I also put injector cleaner in a full tank of gas.
Sep 16, 2019 at 8:58 AM (Merged)
Inspect and test the mass airflow and throttle position sensor-
DRERY
Okay, and how do I go about that? Thank you very much for your quick help!
