Starter & Solenoid are fine. Egine cranks like champ.
To verify no spark I removed plug wire on intake side, connected to a new plug, grounded it & watched while my wife cranked it. No spark, not even a weak one. When key is first turned on you can hear the fuel pump pressurize the fuel rail, (I also just installed a new fuel pump/strainer/sender unit. It's definitely a no spark problem. The volt/ohm meter I have is not digital, so reading small amounts of voltage is not really possible. Payday I plan to get a new one that is auto specific & digital.
Thanx for the wiring schematic. I will check the RED/LT GREEN wire to coil with key on to verify power to coil. Thanx much for your continued assistance.
wiggey
Jul 29, 2020 at 11:46 AM
(Merged)
