Electrical problem
1993 Ford Ranger 4 cyl Two Wheel Drive Manual
I was driving my 93 Ford ranger and it stopped suddenly down the road and I thought maybe it had run out of gas.So I put some gas in and started to crank the motor over but because it was the side of the highway I could not hear the fuel injection pump priming.So I had it towed home. At home I checked the fuel pump and it is priming.I checked the two relays under the hood and they are good, the diode their is also good.The engine cranks over and I checked the spark plugs for spark and their is no spark.So I suspect the coil, the ignition control module or possibly the crankshaft position sensor but the crankshaft position sensor cannot be found?I would like to diagnose the ignition system but I do not know what to look for as for values and positions and where the cranksft position sensor may be or how this ignition works enitrely, and so I need some assistance detecting problems with this ignition to see if this is the problem then procede with a good diagnostic.
Thankyou
Thankyou
May 30, 2009 at 1:32 PM
