I dont have a box behind my coolant res., as it is in the front center of the engine compartment, right behind the fan. The only box I see is behind the batters and the washer fluid res. If thats the box, then:
Which two fuses? Are you referring to the A/C Press fuse (20amp - Constant Control Relay Module)? And what is the EDF relay?
Sorry for the confusion.
Apr 25, 2020 at 5:43 PM
(Merged)
RACEFAN966
CERTIFIED EXPERT
Yes that is the fuse that I am refuring to. It is the a/c press fuse 20 amp. Let me know if that is blown and the edf relay control sends power to the a/c relay and according to mitchell on demand it is located on a bracket behind the coolant reservior. They are calling this unit a constant control relay module and hold the edf and hedf relay and edf relay control and a/c relay thats it. Let me know if you find it and if not then if you would get me the actual production date of you Stang and I will look again. Thanks.
