[quote:9520fc52a5="kaleb417"]hello thanks for your time.i have a 1993 ford f150 with a 302 and 178,000 miles.it started running rough then died.it has power to both wires into the coil but no spark coming out of it.have tryed 2 diffrent coils.same results.have replaced the icm and the ignition switch also.should i try replacing the engine computer?and also where is it located?
thankyou[/quote:9520fc52a5]
Hello !!
check the pick-up coil and igniter...
With a 12 vdc light tester ..
Connect one end to the (-) side of the ignition coil and the other to the (+) side.. crank the engine and see if the light blinks (ON-OFF-ON-OFF) if not the problem its the pick-up coil or the igniter..
let us know to continue!!
good luck!
Oct 14, 2020 at 2:11 PM
(Merged)
