makes front end noise
2009 FORD EXPLORER
I'm glad you got it fixed. It sounded like a bad wheel bearing.
Let us know if you have other questions in the future and thanks for using 2carpros.com.
Apr 14, 2020 at 6:14 PM (Merged)
LUCASTESSA
[quote:a2cc01760b="2CarPro Jack"]Is there any strange wear patter on the tire? try rotating that one to the back and see if the noise changes.Usually a bearing would do that, left turn taking the weight off the l/f wheel[/quote:a2cc01760b]
No wear pattern, switched the front and rear tires with no change. Think I'll open up the front pumpkin to look for any signs of wear coming from driver side "pumpkin bearing"?
SHANER73
I have replaced both axles, both front wheel bearings 8mo ago, driver side bolts came loose and ruined it so i replaced it 3weeks ago. Still have noise coming from front, i took wheels off put car on lift and still hear noise...... i'm at a loss and a new bearing in 180.00 dollars. Trouble happens when making left turns, also hear it a little bit when driving straight.
CARADIODOC
  • 34,306 POSTS
If you're referring to a buzzing noise when moving, that IS caused by the bearing. The torque on the axle nut is critical because that's what holds the bearing together. The most common cause of repeat failures is setting the vehicle's weight on that bearing before the nut is fully tightened. That will instantly damage it but the noise might not be audible right away.
Some people on this site also believe part of the problem is cheap Chinese parts but I don't have any first-hand knowledge of that.
MHODSDON
  • 7 POSTS
hello im working on a ford explorer a 98 ,,its makeing a humming noise almost like a rubbing its not grinding,,but ive changed wheel berrings and rotors and pads,,im stumped ty.
ED-WEEZY21
  • 248 POSTS
Does the humming noise get louder or quieter depending on the vehicles speed?
MHODSDON
  • 7 POSTS
stays about the same its constant,,maybe the front brakes are rubbing i dont no,,but i thought it was the berrings
ED-WEEZY21
  • 248 POSTS
I would double check all the work that has been done. Make sure the backing plate isn't rubbing. If it's possible to lift the vehicle, lift it and have someone put it into drive and slowly hit some gas while you listen to each tire. If I suspect bearings and don't hear anything, I like to touch the strut to feel any vibration and compare each side. Let me know if you find anything.
MHODSDON
  • 7 POSTS
ill check ty
ED-WEEZY21
  • 248 POSTS
You're welcome.
