blinkers do not work
2002 MERCEDES BENZ CLK430
290,657 MILES • 4.3L • V8 • 2WD • AUTOMATIC
BRETTLEZ3
  • 46 POSTS
I let you in on what I've done to the car if I change to sandwiches. I changed the blinker switch twice. I've checked all the realizing change number changed. all the fuses. I've changed the gear, the gear shift. I changed the cable that goes to the transmission. put new light globes in the front after new light globes and stop lights in the back Nearly here I've checked everywhere with the multi-meter and the blinker switch is only getting half the power. the clock spring is getting power but only half the power through it all and the fuses are getting half the power. so I don't know. I change the battery as well. so that is everything I've done to the car.
May 11, 2019 at 7:41 PM
BRETTLEZ3
  • 46 POSTS
would it be an open circuit problem that would that would cause the wipers the blinkers the air conditioning and the boot opening switch inside and the sunroof not to work properly and the horn?
May 12, 2019 at 3:22 AM
BRETTLEZ3
  • 46 POSTS
Did you get the copy of the battery that I sent you? I've gone over everything you said but it's still haven't found the problem. is there anything else that you could advise me on?
May 12, 2019 at 4:32 PM
BRETTLEZ3
  • 46 POSTS
But I still got the problems is there anything else I can do I tried everything you said I've checked the Sands again and I'll check the blinker switch again I've got a new battery as well I checked all the relays and fuses again I said 2 p is there multi-meters is there anything else that you haven't thought of that I can try please I don't know what to do at 8 to another auto electrician and he doesn't know either.
May 14, 2019 at 11:22 PM
BRETTLEZ3
  • 46 POSTS
just replace the clock spring on my clk 430 and that means I replace the clock spring the same module the blinker switch all the relays and the fuses check the Earth and I've still got the same problem what I wanted to ask you is the instrument cluster on the dashboard has that got anything to do with the blinkers and the wipers?
Jun 5, 2019 at 6:12 PM
Yes it works together I would do a CAN scan which you can get a reader from Amazon for about $60.00 here is a video to show you how. This can tell you which part of the system is not working so we can fix it.
https://youtu.be/InIlnsjOVFA
Sep 23, 2019 at 12:34 PM
BRETTLEZ3
  • 46 POSTS
Yeah can I got a problem is black stuff in the fuel filter on the fuel pump side of the filter. I don't know if that means are fuel filters no good or the fuel pump is no good. would you be able to let me know it's on the Mercedes clk 430. thank you
Sep 24, 2019 at 10:11 AM
It sounds like you may have gotten some bad gas. Lets change the filter and see what happens.
Sep 24, 2019 at 10:12 AM
BRETTLEZ3
  • 46 POSTS
Clean the filter out twice now and the same black stuff keeps coming in of drain the tank and the black stuff comes in to the filter it's on the pump side so I don't know if it's coming from the pump the fuel tank but I drained out and I don't know what the problem but I will change the filter and I'll see would black stuff come from the pump itself the pump motor into the filter on the pump side of the filter.
Sep 25, 2019 at 11:32 AM
Okay please let me know. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
Sep 25, 2019 at 11:33 AM
BRETTLEZ3
  • 46 POSTS
It's black stuff I drained Outlast it come out of the side that the fuel pump plugs into.
Sep 27, 2019 at 4:33 PM
You have a bad tank of get I would remove the tank and flush it out. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
Sep 27, 2019 at 4:36 PM
BRETTLEZ3
  • 46 POSTS
Can I flush the tank? I changed the filter but still running really nice. but when it goes up the hill to you it's spluttering like doing it again misfiring and loses power.
Oct 3, 2019 at 12:48 PM
It does this when the fuel supply drops did you replace the pump?
Oct 3, 2019 at 12:49 PM
BRETTLEZ3
  • 46 POSTS
No I didn't should I do that to?
Oct 18, 2019 at 2:10 PM
Yes, Please let me know.
SIALE
  • 13 POSTS
I'm awaiting for fuel pump now to come. Cheers mate for the help...
Oct 22, 2019 at 10:39 PM
Oct 23, 2019 at 10:33 AM
SIALE
  • 13 POSTS
Everything is seemingly good there's no problem with blinkers wipers horn top window or it starting I truly appreciate all the help you have given me mate everything is running sooth at the moment mate cheers
Oct 30, 2019 at 5:37 AM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Oct 31, 2019 at 10:13 AM
BRETTLES3
Can mate I found out what problems it was the ignition switch I took it out in that clean the circuit board and everything and it works again and so does the blinkers and wipers in the whole world thanks I just thought id let you know what it was.
Feb 2, 2020 at 3:27 AM
BRETTLES3
I've got another problem is misfiring 1 and 6 of replace the spark plugs I replace the crankshaft sensor the mass airflow sensor spark plugs I checked all the wires fuel pump fuel filter it's still misfires and runs rough going slow when I pick up speed and I get to 90 100 I don't feel the misfire at all any idea what it could be or what I could check please let me know and I hope you have good New Year I'll be waiting to hear from you
Feb 2, 2020 at 3:30 AM
Please post your new question here, you must be logged in.
Feb 3, 2020 at 10:35 AM
