Questionable performance
2000 DODGE DURANGO
SELFSUFFICIENT
Engine Performance problem 6 cyl Four Wheel Drive Automatic 99000 miles
Why does my truck accelerate slowly, won't switch gears, and shuts off when ac/vent is turned on?
May 3, 2009 at 9:10 PM
Has the check engine light ever come on? It sounds like you have a plugged catalytic converter. Here are a couple of guides so you can run some tests.
https://www.2carpros.com/articles/engine-has-low-power-output
and
Cheers
May 5, 2009 at 11:21 AM
SELFSUFFICIENT
You hit it right on the money it was the cat that was plugged I got it replaced and now it runs like new. I love this site.
May 5, 2009 at 2:09 PM
Good to hear, please use 2CarPros anytime we are here to help.
May 5, 2009 at 7:41 PM
SELFSUFFICIENT
I will! :)
May 5, 2009 at 7:47 PM
HMRODEN
2000 Dodge Durango V8 Two Wheel Drive Automatic
Cannot get truck started, loses all power when I try to crank it. Have tested battery, starter, and alternator. I am at losss for what else it could be and am looking for suggestions. Could anyone help a non-mechanic compile a list of possible causes?
Oct 21, 2017 at 4:01 PM (Merged)
Pick your symptom:
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
DEBORAH DOUGLAS
2000 Dodge Durango V8 Four Wheel Drive Automatic 148000 miles
The gauge lights keep coming on and some heating from engine
Is the engine overheating?
DEBORAH DOUGLAS
I found out that the hose to radiator clamp needed replacing. The coolant was lo
That is good news and an easy fix. Let us know if you have questions in the future.
KRIS2KEEN
  • 5 POSTS
Electrical problem
1998 Dodge Durango V8 Four Wheel Drive Automatic 123000 miles
ok, ive replaced the battery and the alternator...i know both were in good condition cause i took the altenator off my dakota. problem is something is draining large ammounts of power. so bad to were the truck drains and dies after short driving distance...what is it?? i've been told a/c clutch or ground...need this running i got 3 kids...
Oct 22, 2017 at 5:49 PM (Merged)
Here is what I need you to do. You need to check for a draw. It sounds like you will find one. I will provide directions at the end of this post. What to do is this. You will be connecting a volt meter between the neg battery terminal and cable to see the draw. Remove one fuse at a time until the draw stops. That way we will know what circuit is attached to the draw.
Let me know what you find.
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
NOTE: YOU CAN READ ALL THAT IS THERE BUT THE LAST PARAGRAPH IS THE BIGGEST HELP IN YOUR CASE.
KRIS2KEEN
  • 5 POSTS
well i found it it was an a/c clutch drain...i unplugged it and now my volts are at 14 and running great but no a/c...
Have you tried replacing the clutch?
KRIS2KEEN
  • 5 POSTS
i also have an 01 dakota....its flashing a PCM code yet all the forums i've read said their trucks ran fine with that code flashing...mine LAGS really bad...i changed the plugs and plug wires that didnt do the trick. So i was thinking it was the CAT being glogged....whats your take on it?
What code is it? And yes, the converter will cause a power loss.
FLYBOY0183
2002 Dodge Durango V8 Four Wheel Drive Automatic 185000 miles
I have a 2002 Dodge durango with 185,000 miles on it. Lately its been having really bad gas mileage, the engine will rev real high when i press on the gas pedal then a huge cloud of black smoke comes out the exhuast and the truck takes off. It has no real power now and slows really down going up hills. It also has a real strong smell of gas. I've pulled out the oil dip stick and checked the oil fill cap and both smell of oil and gas. I don't know what to check first.
Check the injectors and fuel pessure regulator if it's leaking.If not-inspect and test the following items below:
1.Defective Oxygen Sensors.
2.Coolant temperature sensor out of calibration.
3.Restricted air intake system.
KRIS2KEEN
  • 5 POSTS
its flashing P0601....which is a PCM fault....but others said it ran fine with that code flashing...thats why i figured the CAT was it.
FLYBOY0183
How do I check the injectors and fuel pressure regulator for leaks?
Check the cat because it can cause a power loss as well as other things. Let me know what you find.
For the pressure regulator-pull the vacuum hose,if it has gas then it's leaking.
For the injectors-remove the fuel rail along with the injectors-turn the key on and see if it's leaking.
KRIS2KEEN
  • 5 POSTS
thanks joe...ill let you know im just ready for it to be over hehe
I unerstand. When they run, they're great. However, when there is a problem, they are a pain!
BARRYN
  • 4 POSTS
My wife was getting onto the interstate in her 2001 Dodge Durango 4x4. When she hit the gas, the engine would accelerate, but will not move. We tried putting it in 4 wheel drive, reverse, and nothing. it didnt make any unusual noises or give us any problems leading ..."
DOCFIXIT
  • 18,828 POSTS
Automatic? if yes fluid good if manual clitch slipping?
BARRYN
  • 4 POSTS
Yes, It is an automatic. I just checked the oil and tranny fluid this weekend and the levels were good. I changed the tranny fluid about 10,000 miles back. It wasnt giving us any signs of any issues. Last Friday, we were driving in a snow storm and had it in 4 high, but we didnt go over 45 mph. No problems then.
DOCFIXIT
  • 18,828 POSTS
Not much you can do yourself need to have pressures checked and electronics scanned in trans
BARRYN
  • 4 POSTS
Is there a sensor that could have failed to cause this?
DOCFIXIT
  • 18,828 POSTS
Not that would take out all gears
BURDINE5725
I have a 01 Durango. I just replaced front drive shaft. Something still wrong. When slowing down or giving it gas to go its like the brakes are locking up or something. It has no power but tries to go. It will go after few minutes. Go to turn or slow down.
DOCFIXIT
  • 18,828 POSTS
Would you repost info
BARRYN
  • 4 POSTS
Ok. thanks!
DOCFIXIT
  • 18,828 POSTS
Let me know what repair shop says will advise on repair
SWIFTNESS
2001 Dodge Durango V8 Four Wheel Drive Manual 67000 miles
MY TEMPERATURE GAGUE IN MY TRUCK WENT TO HIGH TEMPARTURE AND THE IT SAIT CHECK GAGUES WHAT DO THAT MEAN.
SWIFTNESS
[quote:d6c2ae9b6d="SWIFTNESS"]Engine Performance problem
MY TEMPERATURE GAGUE IN MY TRUCK WENT TO HIGH TEMPARTURE AND THE IT SAIT CHECK GAGUES WHAT DO THAT MEAN.[/quote:d6c2ae9b6d]
MARKIE777US
  • 14 POSTS
your truck most likely overheated and it spit the coolant out of the radiator, try refilling the coolant and starting the engine, if it hits high temps again then mostlikely you have a thrermostat problem
SMALL99
1999 Dodge Durango V8 Four Wheel Drive Automatic
the engine will lose power at aceleration no mater what speed you are traveling even if you are driving at a set speed it will lose power
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
My 99 Dodge durango loses power when accelerating and now it won't start
