Ironically, that code indicates no codes are stored.
That means we need to go to the ignition switch and see if there is power out from the switch. This means the switch will need removed to access the wiring. At the switch, you will check the wire with the same color as the one on the + side of the coil. It should get power when the key is in the on position.
To remove the switch is a little involved. I am going to provide the directions for replacement. Although you are not replacing the switch, the directions explain how to remove it and then install it. The attached pics correlate with the directions.
1991 BMW 735i (E32) L6-3430cc 3.4L SOHC (M30)
Ignition Switch Replacement
Vehicle Starting and Charging Sensors and Switches - Starting and Charging Ignition Switch Service and Repair Procedures Ignition Switch Replacement
IGNITION SWITCH REPLACEMENT
REPLACING IGNITION SWITCH:
- Disconnect ground lead (battery).
- Remove dashboard trim panel at bottom left.
Cars Without SRS:
- Remove steering wheel.
pic 1
- Unscrew screws and take off lower and upper sections of the steering column casing.
Cars With SRS:
pic 2
- Unscrew screws and take off lower section of the steering column casing.
pic 3
- Pull off plug (4).
- Cut off wire strap (5).
- Loosen holder (6).
- Lift out switch together with the wire harness.
pic 4
- Press in retaining hooks on both sides and pull out the switch.
Installation:
- Check position of the ignition switch to the steering wheel lock.
Let me know if this is something you are comfortable with.
Oct 13, 2020 at 6:43 PM
