Computer control relay location
2005 CADILLAC STS
125,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
You are welcome.
Jul 7, 2019 at 1:51 PM
TCOVALLE
  • 32 POSTS
Error codes cylinders 4,5 and 6 misfires. Replaced sparkplugs ignition coils and fuel injectors. Error codes disappeared and car ran perfect. 30 minutes later ssne cylinder misfires pop up. However, thing is when I clear codes with diagnostic tool, car runs smooth and perfect. Yet 30 minutes later check engine light comes back on and car misfires. Believe problem is with actual ECM instead of actual cylinder misfires. What could be causing this?
Dec 10, 2020 at 7:04 AM
What were the codes that set?
Dec 10, 2020 at 7:12 AM
TCOVALLE
  • 32 POSTS
P0304, P0305 and P0306.
Dec 10, 2020 at 9:03 AM
What are the results of the compression test I requested?
Dec 10, 2020 at 9:23 AM
TCOVALLE
  • 32 POSTS
Compression is good. All sparkplugs ignition coils and fuel injectors are new.
Dec 10, 2020 at 9:32 AM
Okay, what was the compression? Please give me the numbers.
Dec 10, 2020 at 9:34 AM
TCOVALLE
  • 32 POSTS
That's been a while. I honestly couldn't give you an exact number. But all were over 100 PSI. Very little differentials.
Dec 10, 2020 at 10:27 AM
I would retest and get the exact numbers. It makes a difference. You should have 140-160 pounds. If you do not, that could be the issue.
https://www.2carpros.com/articles/symptoms-of-low-compression
Dec 10, 2020 at 10:29 AM
TCOVALLE
  • 32 POSTS
Will do. Thank you. So you don't think it could be an ECM problem?
Dec 10, 2020 at 10:37 AM
Not at this point.
Dec 10, 2020 at 10:41 AM
