No heat?
2008 CHEVROLET UPLANDER
18,000 MILES • 6 CYL • FWD • AUTOMATIC
Check the blend air door. It is located near the heater core. If it is stuck, then you won't get heat
Jul 10, 2020 at 10:52 AM (Merged)
FREEMBA
  • 1,152 POSTS
I saw your other posts before seeing this one, so I've responded several times.
The blend door actuator on the drivers side (closest tot he floor) is most likely the one which controls the heater door. Remove the actuator and turn the rod by hand. with the engine running and at normal temperature you should then feel heat. Try this several times to be sure its the proper one. if so then repalce the actuator.
T. ALMOND
Read my posts at the very bottom of the page at this link to the Chevrolet forums. In particular this has to do with the Uplander. https://chevroletforum.com/forum/uplander-31/2008-uplander-heat-problem-20931/page10/#post486041
Jan 1, 2023 at 5:44 AM
T. ALMOND
Try this again. Read my posts at the bottom of this page if you have an Uplander with no heat at idle. https://chevroletforum.com/forum/uplander-31/2008-uplander-heat-problem-20931/page10/#post486041
Jan 1, 2023 at 5:46 AM
