My battery drains out like there is a draw why??
2003 CHEVROLET SILVERADO
HUISH
  • 4 POSTS
My truck is the LT model. it is not starting after about three days of not running. So far we have taken it to three different mechanics and they all say that they do not know why the battery is dying. We have changed the battery. Something is clearly pulling power from the battery while the truck is off. Does anyone have any ideas as to what it could be? Any help would be greatly appreciated. Thank you for your help!
Nov 20, 2009 at 7:32 PM
IMPALASS
  • 3,112 POSTS
Here is a guide that can help you see if the problem is easy:
https://www.2carpros.com/articles/car-battery-dead-overnight
Also
I searched through about three hundred or more TSB and came up with a couple of things.
The first one below states the when diagnosing battery draws on trucks equipped with the automatic dual zone HVAC controls (RPO CJ2), technicians should keep in mind that the control head does not completely go to sleep and may drain the battery. Before I go any further on this do you have manual or automatic HVAC controls?
Automatic Dual Zone HVAC Battery Draw
TECHNICAL SERVICE BULLETIN
Reference Number(s): 02-01-39-007B, Date of Issue: November 05, 2007
Affected Model(s): 2004-2007 Buick Rainier; 2003-2008 Cadillac Escalade Models; 2002-2008 Chevrolet TrailBlazer; 2003-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe; 2002-2008 GMC Envoy Models; 2003-2008 GMC Sierra, Yukon Models; 2002-2004 Oldsmobile Bravada; 2003-2008 HUMMER H2, H3; 2005-2008 Saab 9-7X
Supercedes: This bulletin is being revised to add models and model years. Please discard Corporate Bulletin Number 02-01-39-007A (Section 01 - HVAC).
Related Ref Number(s): 02-01-39-007, 02-01-39-007A, 02-01-39-007B
ARTICLE BEGINNING
SERVICE INFORMATION
When diagnosing battery draws on trucks equipped with the automatic dual zone HVAC controls (RPO CJ2), technicians should keep in mind that the control head does not completely "go to sleep" until after 150-250 minutes, or up to 4-1/4 hours, from when the ignition key is turned OFF. This is a normal condition. In these cases, do not replace the control head.
Now they also had a TSB on Parasitic drain, I put that here so I would not lose it, and for your information, but before we do that load test let's look at a couple of other things.
Battery Parasitic Drain
Reference Number(s): 02-06-03-010A, Date of Issue: July 02, 2004
Affected Model(s): 2005 and Prior Passenger Cars and Trucks; 2003-2005 HUMMER H2; 2003-2005 Isuzu Light Duty Trucks
Supercedes: This bulletin is being revised to add the 2004 and 2005 model years. Please discard Corporate Bulletin Number 02-06-03-010 (Section 06 - Engine).
Related Ref Number(s): 02-06-03-010, 02-06-03-010A
ARTICLE BEGINNING
SERVICE INFORMATION
In automotive terms, a parasitic drain is an electrical load that draws current from the battery when the ignition is turned off. Some devices, such as the PCM and the radio memory are intended to draw a very small amount continuously. These draws are measured in milliamps (mA).
In normal use, parasitic drains aren't usually cause for concern, because the battery is replenished each time the vehicle is driven. But, in long-term parking situations, parasitic drains may discharge the battery enough to cause a no-start condition. New vehicles in dealer stock and airport long-term parking are two such situations.
An abnormal parasitic drain could be a glove-box or luggage compartment light that remains on but undetected. Or an electronic component may malfunction and cause a parasitic drain that is larger than normal specification.
PARASITIC DRAINS AND ON-THE-LOT BATTERY DISCHARGE
IMPORTANT: In most cases of discharged batteries in low-age, low-mileage vehicles, proper charging procedures with approved charging equipment is the only repair necessary.
Here are some rules of thumb that might help relate parasitic drains to how long a battery would last on a parked vehicle.
The Reserve Capacity (RC) rating multiplied by 0.6 gives the approximate available ampere-hours (AH) from full charge to complete rundown. Somewhere between full charge and complete rundown, the battery will reach a point at which it can no longer start the engine, although it may still operate some of the electrical accessories.
Using up about 40% of the total available AH will usually take a fully-charged battery to a no-start condition at moderate temperatures of 25°C (77°F). Put another way, for a typical battery in a storage situation, depleting the available AH by 20 to 30 AH will result in a no-start condition.
IMPORTANT: If the battery begins storage at 90% of full charge, reduce the available AH accordingly.
The recommendation for maximum parasitic drain is around 30 mA (0.030 amp). A typical drain today actually falls into the 7-12 mA range, even though some vehicles do approach the maximum. Multiply the drain (in amps) by the time (in hours) the battery sits without being recharged. The result is the amount of AH consumed by the parasitic drain. The actual drain may be small, but over time the battery grows steadily weaker.
Here's an example: a vehicle with a 30 mA drain and a fully-charged 70 RC battery will last 23 days. But if that battery is at only 65% of full charge (green dot barely visible), it is going to last only 15 days before causing a no-start.
EFFECTS OF TEMPERATURE ON A STANDING BATTERY
The parasitic drain will be fairly constant over a range of temperatures. The important temperature is that of the vehicle at the time a start is attempted. Colder temperature raises the threshold of a no-start by increasing the residual power needed. When the temperature falls to 0°C (32°F), the battery will be able to put out only about 85% of its normally available starting power, and the engine may need as much as 165% of the usual power to start.
The combined effect of these two factors is to reduce the number of days the battery can stand with a parasitic drain. At 0°C (32°F), the battery can stand only half as long as it could at 25°C (77°F). And at -19°C (0°F), the standing days are reduced to one-fourth.
Temperatures above the moderate climate of 25°C (77°F) increase the battery's internal self discharge. If the battery is in a locale where the temperature is averaging 32°C (90°F), an additional 5% to 10% of the available ampere-hours will be lost in a month due to self-discharge within the battery. At temperatures below the moderate range, self-discharge will be low enough to be negligible compared to the parasitic loss.
WHAT THE POLICIES AND PROCEDURES MANUAL SAYS ABOUT PARASITIC DRAINS
Because determining how long a battery may last in a storage situation is not precise, the P & P manual provides a clear-cut policy, excerpted here.
"Discharged batteries can freeze at temperatures as high as 0°C (32°F), causing permanent damage. Other permanent damage may result from allowing batteries to stand discharged for extended periods."
"To alleviate this condition, the negative battery cable should be disconnected on vehicles which are not going to be in service within a 20 day period, beginning from the time the vehicle is shipped. If this is not possible, batteries should be recharged periodically, every 20-45 days, until the green eye is visible."
"Disconnected batteries will slowly discharge, especially with higher temperatures; therefore, even disconnected batteries should be checked every four months and recharged if necessary."
"Vehicles on display are subject to battery discharge due to drains from courtesy lights and other accessories. Provision to maintain battery state of charge for these vehicles will be necessary."
Consult your P & P manual for full details.
TRACKING DOWN THE SOURCE OF A PARASITIC LOAD
If the battery in a vehicle becomes discharged in a shorter time than described earlier, the vehicle may have an out-of-specification parasitic load. Refer to Service Information (SI) for procedures for locating parasitic drains. Follow these steps:
1. Build the vehicle.
2. Select the Engine section.
3. Select the Engine Electrical sub-section.
4. Select Diagnostic Information and Procedures.
5. Select Battery Electrical Drain/Parasitic Load Test.
You will need the J 38758 Parasitic Draw Test Switch and a digital multimeter set to the 10A scale.
IMPORTANT: Read the procedure and follow the steps exactly as described in SI. The following is a summary, not the complete procedure.
The test switch permits you to place an ammeter in series with the battery negative cable. Before performing the test, the engine must be run and all accessories must be operated as instructed. After shutting the ignition off, turn the test switch off. Now, all the current being used by the vehicle is shunted through the ammeter where it is measured. If the reading is out of specification, the procedure explains how to pinpoint the cause.
A FINAL WORD ABOUT BATTERY TESTING
Your dealership has an essential tool, the Midtronics Micro 410 Battery Tester, J 42000. Use it to quickly identify batteries that are serviceable and can be charged. Refer to Corporate Bulletin Number 02-06-03-006A for more information about this tool.
This one was interesting as the ignition switch does not always turn off.
Diagnostic Information for Intermittent Vehicle No Crank/Dead Battery
Reference Number(s): 04-06-03-002, Date of Issue: February 05, 2004
Affected Model(s): 2004 Buick Rainier; 2000-2004 Cadillac Escalade; 2002-2004 Cadillac Escalade EXT; 2003-2004 Cadillac Escalade ESV; 1998-2004 Chevrolet Blazer, S-10 Pickup; 1999-2004 Chevrolet Silverado; 2000-2004 Chevrolet Suburban, Tahoe; 2002-2004 Chevrolet Avalanche, TrailBlazer, TrailBlazer EXT; 2003-2004 Chevrolet Express; 1998-2004 GMC Jimmy/Envoy, Sonoma; 1999-2004 GMC Sierra; 2000-2004 GMC Yukon, Yukon XL; 2002-2004 GMC Envoy, Envoy XL; 2003-2004 GMC Savana; 2004 GMC Envoy XUV; 1998-2004 Oldsmobile Bravada; 2003-2004 HUMMER H2
Related Ref Number(s): 04-06-03-002
ARTICLE BEGINNING
SERVICE INFORMATION
When diagnosing a concern regarding an intermittent vehicle no crank or dead battery, technicians should remove and reinstall the ignition switch using the Ignition Switch Replacement procedure in the Steering Wheel and Column section of SI. The ignition switch may have been misindexed in the steering column during a previous replacement .
If the ignition switch is misindexed in one direction, the ignition switch circuits will not be completely open when the ignition switch is in the OFF position with the key removed. This may result in lights remaining on or instrument panel lights illuminating, which will drain the battery. If the ignition switch is misindexed in the opposite direction, the ignition circuits will open correctly but the ignition switch may not close the crank circuit properly when the ignition key is turned to the crank position. This will result in a no crank concern.
This is my suggestion;
First, see if you can have your truck in total darkness and see if the glove box light or any other lights are on very dim.
If not then I would pull the fuses below and see if that makes a difference.
Under-hood fuse block left side near battery pull ignition A Fuse 40 Amp and ignition B Fuse 40 Amp.
Next, how old is your battery? This may be as you read above with the HVAC if you have that system (please let me know) then it may drain your battery quicker.
Please go to Auto Zone (AZ) or O Reilly's (or) and for free they can pull the codes to the car. Most important: Once they check your codes, if they find something and you do not get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 sensor bad. Then make sure you give us all of that. While there for free also they can bring their tester out and check your battery and alternator.
The big thing I am checking here is the strength of your battery, they may say it is getting weak. Make sure it is fully charged before you have them check it.
Then if needed I will send you more information on how to do a parasitic draw test. Unless you want it right now and I will be glad to provide that. Just let me know.
I just did not want to flood you with too much information. Just let me know.
Dec 18, 2020 at 9:12 AM
HUISH
  • 4 POSTS
Thank you for the information. I will try to get the truck in like you suggested. Thanks!
IMPALASS
  • 3,112 POSTS
I did not mean if you had a automatic transmission. I apologize if I was unclear.
That first TSB speaks of the automatic dual zone HVAC controls (RPO CJ2). This is for your air conditioner and heater controls, some models are manually controlled and some are automatically controlled. Do you have the manual control or automatic?
No problem for the information. Let me know how it goes.
HUISH
  • 4 POSTS
Oh I am sorry, I understood what you were talking about. I do not know why I said transmission. But yes, my HVAC controls are automatic. Thank you!
IMPALASS
  • 3,112 POSTS
Okay, then that should still be an option about the battery being a little weak and the head of the air conditioner controller not going into sleep mode for several hours okay up to 4.5 hours.
So I would still do a check on the battery and when was the last time it was changed? Also, how long ago did this start? What changed with how your were driving etc., prior to it starting to go out? Can you think of anything?
HUISH
  • 4 POSTS
Well the battery was changed this summer. I am from WI, but I have been away since June on a job. This problem happened once I left and my mom and step dad started driving it. They drive it every few days for me to go to work and running errands and stuff just to keep everything working on it. I did not have a problem before when I drove it. I asked them to make sure to check all of the lights and everything to make sure they turn everything off. They said that they are not leaving anything on. Hopefully we can get this problem fixed. Thanks!
IMPALASS
  • 3,112 POSTS
Hello, Thanks for the information it certainly is a mystery. Unless you received a bad battery it would still seem odd if it is driven why it goes dead. Still the battery/alternator checkout may tell us something. Hey, I am going to give you how to do the parasitic draw test. Battery Drain Parasitic Draw Testing © Copyright 2000 - 2006 Chuck Kopelson 12/01/2003 Updated December 14, 2008 If this site has helped you consider a Donation. Donation Info by Wayne O. Wenzlaff and Chuck Kopelson 4/15/2007 What is parasitic draw? All vehicles draw some power from the batteries when the car is shut off. Certain accessories such as clocks, radios remote door openers and alarms always need power. The normal power used is called parasitic draw. It is always a very low draw so it doesn't run the battery down. If you install accessories like shortwave radios or plug things like invertors and portable refrigerators into the accessory socket and operate them too long without the engine running you can drain your batteries to the point where the engine won't start. If there is an electrical short in the vehicle or a malfunctioning accessory it could be drawing much more than its normal load causing a drain on the batteries. If you leave your door open and the inside lights stay on all night you could drain the battery down till the car won't start. My 98 draws 3.5 amps with the front door open. Usually what happens is the truck is dead when you first go to start it. The first thing to do is a test for a major short. Remove the positive and negative cables from the batteries. Put an Ohm-meter across the positive and negative cable. If your reading is close to 0 Ohms then you have a direct short. I read 150 ohms on my stock 98. You need to trace the short before you can perform the following tests.
https://www.2carpros.com/forum/automotive_pictures/248015_Volt_Meter_2.jpg
In order to check for parasitic draw, you need to be careful so you don't ruin your meter. At the risk of sounding like an elementary teacher, here's what you need to do. 1. If you don't already have one, get a digital meter capable of reading up to 10 amps DC. Sears sells them for less than $50 - I bought one on sale for $14.99 that I leave in my truck. 2. Your battery must have a reasonable charge for this test - it won't work if your battery is dead. Quick proof - if your dome light operates normally, you're fine. My truck wouldn't start and the batteries were down to 5.5 volts so I put a charger on the batteries overnight. They are now 12.2 V. When I started the truck the voltage went to 14.3 V so the alternator is working. 3. Check to make sure ALL loads are turned off. Unplug anything you may have plugged into the cigarette lighter. Remove your keys from the ignition. Close all doors so the dome lights are off. 4. Disconnect the thick positive (Red) cable that goes down to the starter. 5. To start make sure your meter is set to the 10 amp DC range. Some meters have a special connector for the red probe when you are reading current. The meter pictured on the left has one jack for high amps and one for low amps. If yours does, make sure the meter end of the probe is in the right connector. You can either do this next step by just holding the meter probes to their respective contact points (you won't get a shock from 12 volts) or you can use probes with alligator clips to snap them in place so your hands are free to do something else. 6. Connect the positive probe to the battery - either battery is fine, electrically speaking, since they are connected together by the negative (Black) wires. Polarity on digital meters doesn't matter because they are autosensing. 7. Connect the negative probe to the red cable that is still connected to the vehicle. Make sure this cable and your probe do not touch ground. 8. If there is a severe current draw (more than 10 amps) it will either pop a fuse in your meter or destroy it outright. That's why you need to test for a short, otherwise, your meter should now be reading the current drain on your battery. 9. If your vehicle has an alarm system or remote locks, the current draw may be around 2-3 amps for a few minutes after you last close the door. This is normal. If you're not sure, wait at least twenty minutes after you last open or close a door before you take a reading. 10. If everything is normal, you will read less than 35 milliamps, or .035 amps. If the current drain is higher than that, you need to find out what is draining your batteries: You can start by pulling fuses until the load goes away. If that doesn't reduce the draw, you need to look for a wire that is corroded or frayed.
https://www.2carpros.com/forum/automotive_pictures/248015_Battery_and_Meter_2.jpg
PIGGSTAA
I had the same problem. Disconnect the PCM connectors and look for corrosion.
Great addition to this thread! Please feel free to help out whenever you are on the site :)
DARTHRAIDER
my battery drains while truck is shut off, i have to jump start it every day, i have a maintenance free battery.and after i get it started my dashboard is informing me that battery is not charging my lights are dim, then in a split second lights are bright battery starts charging and the process repeats it self everyday...i was told to start the truck and then disconnect both positive and negative from the battery and if the truck shuts off then it was my alternator and if it did not shut off then it was my battery.
May 13, 2021 at 6:39 PM (Merged)
Get the alternator and battery load tested. Sounds as though the voltage regulator is not controlling the alternator field windings therefore its not producing the correct output. Battery drain overnight could be a short circuit within the electrical system.
This guide can help us test it.
and
CAPT JACK
Alternator and battery are new but the battery goes dead overnight. When I remove the two wire plug from the alternator and put a tester between the battery and positive cable it draws about 6.5 amps even after the truck has set for an hour or more. Where do I go next.? When I remove the battery cable, I hear a sound like a switch clicking off. I hear it again when I connect the battery. Sure has me puzzled.
HMAC300
  • 48,601 POSTS
go here
CAPT JACK
I found the problem. It turned out to be a stuck relay for the a/c compressor. On a particularly humid and chilly day I noticed frost an an a/c line after the truck had been shut off for some time. Thanks much for the help.
JOSEPH WOOTEN
I have a 1500 z71 5.3 v8. my battery is drained after sitting for a few days. I have replaced the battery, replaced the starter after founding out that they were both bad. Look for a parasitic drain and saw it was the radio, so I bypassed it so it would completely shut off when the truck is off and still the battery is still draining and completely drained after a few days. My last option is replacing the alternator. Can anyone help please? And tell me what is wrong? I really do not have the money to take it to a mechanic.
May 13, 2021 at 6:40 PM (Merged)
HMAC300
  • 48,601 POSTS
do the parasitic draw test once again and then go to the ABS unit and unplug that see if it stops. that has been a problem on a few vehicles.
JERMIAJR42
  • 8 POSTS
Truck runs good, but recently when engine is turned off the battery is being drained and goes dead, while driving it shows charging, and when you shut it off it is dead and has to be jump started. lights work but wont start. this is a problem that continually worsened over time until it now will not hold charge when shut off. put new battery in and was okay for several weeks but gradually got to the point where we are now.
SCGRANTURISMO
  • 4,897 POSTS
This definitely sounds like a case of parasitic draw. Parasitic draw is a component that is either unintentionally left on or has shorted to power and is slowly draining all the electricity out of the battery when the vehicle is off. Here is a link for you to go to down below:
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
LARRY
  • 4 POSTS
O K here is the problem my 2000 Silverado Z71 4x4 keeps draining the battery.Put new 60mo battery in and overnight the battery is dead, took it to carquest and it tests good. put meter between the neg terminal and the disconnected neg cable voltage is 12.8 pulled all the fuses in eng. compartment one at a time no change. Then removed each fuse in cabin pnl and no change what is killing my batt????
CALLENRSUE
  • 19 POSTS
I find it more accurate to use a test light between neg cable and the neg post. Sometimes voltage regulators in alternators can cause a large draw like that. I would pull the plug connector and see if the test light goes out doing that.
That is good advice. Remove the power to the alt but keep in mind, with the battery connected, the power to the alt is hot. One other thing about the alternator are the diodes in it. They are designed to allow power to travel in one direction only. If you have a bad one, it will short to ground and drain the battery. The alternator will still charge when the engine is running, but drain the battery when off.
WEAZZZ22
Well one night there was a wreck on my road. I went up there to help, stoped turned my hazard lights on and the botton shot out. When i got back home the button would not stay down but the lights were still flashing so i pushed a little harder and the horn honked as the lights were flashing.The horn stoped and i stoped messing with it. So i took the fuse out so the hazards would stop flashing. The next moring i tried to start it the battery was dead. so i put the fuse in, the hazzards didnt work so i charged the battery got it checked it was fine.Then the blinkers didnt work and now everytime i turn the truck off about 5 or 6 hours later the battery is dead. PLEASE help me.
May 13, 2021 at 6:41 PM (Merged)
What you got is a direct short to ground within the electrical system maybe and could involve the hazard circuit. Get a test light -disconnect the negative cable on the battery put test light between the disconnected cable and battery negative post-the test light will lit if you have a short in the system that's eating up the battery.
To find it start removing fuses one by one till the light turns off-this is where the trouble is located.
WEAZZZ22
[quote:9d91e5f9f6="rasmataz"]What you got is a direct short to ground within the electrical system maybe and could involve the hazard circuit. Get a test light -disconnect the negative cable on the battery put test light between the disconnected cable and battery negative post-the test light will lit if you have a short in the system that's eating up the battery.
To find it start removing fuses one by one till the light turns off-this is where the trouble is located.[/quote:9d91e5f9f6] Thanks man it worked i would give you points but i dont have any if i did i would give you 100
Its okay -half of the time it doesn't work or you don't have enough posts to do it. You have a nice day.
AGGIE 1
changed alternator, replaced battery. I am at a loss.
94 TRANSAM
  • 680 POSTS
Hello, We are sorry you are having troubles. Let me see if I can help you out.
If your battery is going from a full charge to dead over night it could be a couple of things.
1: Your battery has reached its life span and will no longer hold a charge. In which case you will need to replace it. Many part stores cant test your battery to see if it is good for free. Check with your local auto parts dealers to see who will do this for you at no charge. You can just walk in with the battery. You do not need to bring the car.
2: You have a draw on the battery that is draining it. Here is a link to show you how to test your system for a draw should the battery turn out to be fine:
If you need more help or have more questions with this issue please feel free to come back and ask. And if this resolves your issue please let us know. Have a great day! Rich.
EJ GOBERT
I replaced my battery and it worked fine for about a month then it would drain over night like the last one.
May 13, 2021 at 6:42 PM (Merged)
Good morning.
Did you check the charging system?
If it is overcharging, it will boil a battery and fail the battery. Use a voltmeter and see if the charge rate is 14 to 14.5 volts.
Did you also check for a draw?
HARLEYMAN2
is there any easy way to dectect a short, my battery is fine for about 4 days then dead, i've installed two new battery's and not the cheap ones, di the alternater test and thats fine.
May 13, 2021 at 6:44 PM (Merged)
JDL
  • 16,098 POSTS
A battery drain with everything turned off? The best time to check for a lite staying on, is in the dark, under the hood, in the cab, somewhere. You can take battery cable loose, use testlite between cable and battery posts. If the lite is on, pull fuses one at a time. When you pull the fuse on the faulty circuit, the lite goes out. If you have a lite under the hood, you have to account for that and keep the doors shut.
DMPHILPOTT
My pickup battery dies consistently after about 3 or 4 days of not running it. I've replaced the alternator and battery; also had them both tested and RE-tested. Pass with flying colors. Nothing is being left on in the truck. I've checked all lights including the courtesy lamps under the hood. My A/C hasn't been run in quite a while due to an issue with the "flap" that diverts air to the specified vents. When I shut off the truck or start it, it pops five or six clicks then stops and does it again for about 8 cycles. I cannot for the life of me find out why. I've pulled fuses one by one and found that with the vehicle off, the courtesy fuse arcs. This is the only one that does it. Also my amp gauge bobbles when the turn signal is used even at 70mph. Any ideas how to make this truck more reliable?
MMPRINCE4000
  • 8,548 POSTS
I would install a battery shut off on negative cable, when you turn it, it will cut battery power to engine.
This will erase clock settings and radio presets, but it will tell you if there is a battery drain.
Some autoparts stores have a device that will measure drains on battery when engine is off.
But drains are hard to isolate without proper equipment.
Also check relays with engine off, after engine cools, quickly touch relays, if any are hot, then relay is stuck.
PBMB04
Battery drains slowly when vehicle is parked for a period of time. Also, gauge shows charging at 14 amps when first driving but at later will only show a charge of 12 amps after driving for a while. Can you help in what I should be checking?
May 13, 2021 at 6:45 PM (Merged)
I need you to check two things. First, we need to check if the alternator is working when it reads 12 volts. The 14 you mentioned sounds normal. If it drops to 12, the alt may be going bad. When it is reading 12 volts, run this test:
https://www.2carpros.com/how_to/how_to_test_alternator.htm
After that is complete, I need you to check for an electrical draw. Here are the directions for that:
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
Let me know the outcome of both so I can point you in the right direction. If there is a draw, remove one fuse at a time to see what circuit is causing it. The draw should stop when you hit the right circuit.
PEDRO ANGEL MADERA
I just purchased this truck and it completely drains the battery within a day. I just bought a new battery and it was drained so i took it to the local store to get it charged. I measured it to be 11.6 volts. As soon as i plugged in the terminals it read 5.4 volts. i disconnected the terminals and measured the battery again and it was at 8.4 volts. I have made sure all lights are off, removed the stereo and still nothing.
May 13, 2021 at 6:46 PM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
This definitely sounds like your vehicle has a parasitic draw issue. Parasitic draw is an industry term. We use it when, just like in your case, a vehicle has some kind of electrical draw that will drain a vehicle's battery, even when the vehicle is shut off.
I have included a link to a guide for you down below.
Please go through this guide and get back to us with what you find out. And make sure you have got a really good charge on your vehicle's battery before you start please. It will make things alot easier.
Thanks,
Alex
2CarPros
PEDRO ANGEL MADERA
I was getting a 50 mA draw. I found that it was the park-lps fuse.
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Awesome, that's what we like to hear.
Thanks,
Alex
2CarPros
DAN NEFF
Battery goes down couple days. Battery cks o k. alternator checks ok. Took positive cable loose from battery and measure resistance to ground get almost half meter reading, but open door or raised hood to when lights ( if connected ) would come on I get "0" resistance, which shows the positive cable is grounded.
Should there be any restistance any time cable unhook and where do I go to from here? What is causing the problem?
PS I cannot find any bare wires.
Thanks Dan
May 13, 2021 at 6:47 PM (Merged)
