Same problem with my 1996 Lumina sedan.
If I put the turn signal in its locked position, the in-dash signal indicator blinks rapidly, which would normally indicate a burnt-out bulb. However, if I hold it slightly out of position, it works fine.
The cruise control stopped working for a few months. Its switch is part of the multifunction switch. It started working again spontaneously after a few months.
Now the brake lights don't work reliably, unless I hold the turn signal position slightly forward when I press the brakes.
Something buggy here, I think.
Aug 15, 2020 at 11:16 AM
(Merged)
