Engine will not start
2001 CHEVROLET EXPRESS
50,000 MILES • V8 • 2WD • AUTOMATIC
CARADIODOC
  • 34,306 POSTS
Everything you described sounds typical of a bad connection on a battery cable or where the smaller positive wire bolts to the under-hood fuse box. Finding this should be easier since you can get it to go to the bad condition. Turn the headlights on so some current is always trying to flow, then start right on the battery bolts and measure the voltage. If you find 12.6 volts, move one meter probe from the negative post to a paint-free point on the body. You should find the same voltage. Move the probe from the positive bolt to the stud on the fuse box. You're looking for the first place the voltage is considerably lower. That will be the point of the bad connection.
Dec 17, 2019 at 1:08 PM (Merged)
FUTANT
Thank you for the advice. I will do that when it slows down raining here.
PCONTE
I have a 2001 Chevy cargo van. New battery,New starter, new starter relay,new fuel pump relay. I replaced all this because the van would not start. This morning when I went to start the van I got the click click then finally it started. Also this van has had 2 ignations installed. What is the starting problem?
JDL
  • 16,098 POSTS
If your saying, there was no starter action at first, and the clicking came from the starter relay, I'd check voltage reading at the control side of the relay. A relay may click a lot when there is not enough available voltage to keep the relay closed. You'll have to test when the problem occurs. It might be a problem with a wiring circuit or connector?
