First, the charging kits that you can get from most retail stores is designed to fit the suction fitting only which is a 13 mm fitting. The fittings are designed that way to prevent you from putting the can on the discharge port, which could cause the can to explode due to overpressurization. First check that you are getting 12 volts at the connector going to the compressor and that you have a good ground.
If both are true, try disconnecting the low pressure switch and jumpering the connector's two terminals with a piece of wire or a paperclip. If the compressor will not come on then your problem is either a bad compressor or the compressors clutch coil is bad. If you don't have power then check your fuses for a blown one. Hope this helps.
Later
Gary
Jul 16, 2020 at 10:07 AM
(Merged)
