When the vehicle refuses to start, do you have spark at the plugs, with the engine cranking? Have a helper crank it, while you check for spark. Just pull a plug boot, use a spark tester or a known good plug in the boot. If you use a spark plug, you need to ground the metal part of plug to metal part of engine. A spark tester usually has a ground clamp on it.
If there is no spark at the plugs during cranking, my first thought was the crank sensor, but, you need to do some testing to be sure.
Are there any codes?
Jul 18, 2019 at 10:09 AM
(Merged)
