Check engine light, code P0101
2003 CHEVROLET 1500
240,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
KEITHC21
  • 41 POSTS
Check engine light has been on for a few weeks now. when it first came on it was not on all the time it was on/off but now it is always on. I checked the code with a code reader and it is code P0101, mass airflow circuit range performance. (Mass airflow sensor is out of expected range) So I did a little research on causes of this code and ended up checking the intake gaskets for vacuum leaks, the vacuum hoses, the vacuum pressure, the exhaust back pressure, and the wires to the MAF sensor. All looks good. So then I cleaned the MAF sensor and throttle body. then I used a multi-meter to check voltage to and from the MAF sensor, results were as follows, 12 volts supply = good. 12 volts ground = good. Now the return signal wire i believe something is off, it was around 4.40 volts -4.75 volts at idle and then *decreased* to around 4.05 volts - 4.39 volts at 2,000 rpm's. So I did some research on the type of MAF sensor this truck has and it is a “hot wire” type MAF sensor. I found There is a element inside the sensor that heats up to a specific temperature when the vehicle is started, then as rpm's increase and air is sucked in it cools the element causing it to need more voltage to keep the element at the specific temperature. This increase in voltage is how the computer knows how much air is being sucked into the engine. But, since with mine, the voltage decreased when the rpm's increased. Causing the code to be set. Now I am just trying to be sure, is this a faulty/worn out MAF sensor? Or am I possibly missing something? Please help! This has been driving me nuts for weeks! I just really need to be sure what exactly the problem is because I do not have the money to be replacing parts that do not need to be replaced.
Dec 25, 2017 at 1:37 AM
Good morning.
I will get the description for you for the code. One thing, you cannot clean a mass air flow sensor. the hot wire gets carbon burned on the end and that is a big reason for the bad readings. there is no cleaner for the hot wire as no cleaner can remove burned on carbon.
Below is the description. It does sound like you have a failed sensor
CIRCUIT DESCRIPTION:
The mass air flow (MAF) sensor is an air flow meter that measures the amount of air entering the engine. The powertrain control module (PCM) uses the MAF sensor signal to provide the correct fuel delivery for all engine speeds and loads. A small quantity of air entering the engine indicates a deceleration or idle condition. A large quantity of air entering the engine indicates an acceleration or high load condition. The MAF sensor has the following circuits:
- An ignition 1 voltage circuit
- A ground circuit
- A signal circuit
The PCM applies a voltage to the sensor on the signal circuit. The sensor uses the voltage to produce a frequency based on the inlet air flow through the sensor bore. The frequency varies within a range of near 2,000 Hertz at idle to near 10,000 Hertz at maximum engine load. The PCM uses the following sensor inputs to calculate a predicted MAF value:
- The manifold absolute pressure (MAP) sensor
- The intake air temperature (IAT) sensor
- The engine coolant temperature (ECT) sensor
- The engine speed (RPM)
The PCM compares the actual MAF sensor frequency signal to the predicted MAF value. This comparison will determine if the signal is stuck based on a lack of variation, or is too low or too high for a given operating condition. If the PCM detects the actual MAF sensor frequency signal is not within a predetermined range of the calculated MAF value DTC P0101 sets.
CONDITIONS FOR RUNNING THE DTC
- DTCs P0102, P0103, P0106, P0107, P0108, P0120, P0220, P0442, P0443, P0446, P0449, P0455, P0496, P2135 are not set.
- The engine is cranking or running.
- The ignition 1 signal is between 11-18 volts.
- The throttle position (TP) indicated angle is less than 95 percent.
- The change in the TP indicated angle is less than 5 percent.
- The MAP sensor is more than 17 kPa.
- The change in the MAP sensor is less than 3 kPa.
- The above conditions are met for 1.5 seconds.
CONDITIONS FOR SETTING THE DTC
The PCM detects that the actual MAF sensor frequency signal is not within a predetermined range of the calculated MAF value for more than 4 seconds.
ACTION TAKEN WHEN THE DTC SETS
- The PCM illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
- The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the operating conditions to the Freeze Frame and updates the Failure Records.
CONDITIONS FOR CLEARING THE MIL/DTC
- The PCM turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
- A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
- A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
- Clear the MIL and the DTC with a scan tool.
DIAGNOSTIC AIDS
- Inspect the harness of the MAF sensor to verify that it is not routed too close to the following components:
- The secondary ignition wires or coils
- Any solenoids
- Any relays
- Any motors
- A low minimum air rate through the sensor bore at idle or during deceleration may cause this DTC to set. Inspect for any vacuum leak downstream of the MAF sensor.
- Inspect for any contamination or debris on the sensing elements of the MAF sensor.
- Inspect the air induction system for any water intrusion. Any water that reaches the MAF sensor will skew the sensor and may cause this DTC to set.
- A wide open throttle acceleration from a stop should cause the MAF sensor parameter on the scan tool to increase rapidly. This increase should be from 3-10 g/s at idle to 170 g/s or more at the time of the 1-2 shift. If the increase is not observed, inspect for a restriction in the induction system or the exhaust system.
- A high resistance of 15 ohms or more on the ignition 1 voltage circuit may cause this DTC to set. A high resistance may cause a driveability concern before this DTC sets.
- The barometric pressure (BARO) that is used to calculate the predicted mass air flow value is initially based on the MAP sensor at key ON. When the engine is running the BARO value is continually updated near wide open throttle. A skewed MAP sensor will cause the calculated mass air flow value to be inaccurate and may result in a no start condition. The value shown for the MAP sensor display varies with the altitude. With the ignition ON and the engine OFF, 101 kPa is the approximate value near sea level. This value will decrease by approximately 3 kPa for every 305 meters (1,000 feet) of altitude.
- A high resistance on the 5-volt reference circuit of the MAP sensor may cause this DTC to set.
- A high resistance on the low reference circuit of the MAP sensor may cause this DTC to set.
- If the condition is intermittent, refer to Intermittent Conditions. See: Computers and Control Systems > Initial Inspection and Diagnostic Overview > Intermittent Conditions
TEST DESCRIPTION
Steps 1-4
imageZoom/Print
Steps 5-6
imageZoom/Print
Steps 7-9
imageZoom/Print
Steps 10-15
imageZoom/Print
The numbers below refer to the step numbers on the diagnostic table.
5. This step will determine if the MAP sensor pressure is within the proper range for a given altitude.
6. This step will determine if the MAP sensor voltage is within the proper range at idle.
7. This step will determine if the MAP sensor responds properly to the change in manifold pressure.
8. This step will determine if the TP sensors are operating properly.
9. This step will determine if any mechanical faults have caused this DTC to set.
10. This voltage drop test will determine if high resistance has caused this DTC to set.
Dec 25, 2017 at 6:08 AM
KEITHC21
  • 41 POSTS
Hmm, maybe the element is carbon burned then, seeing as the sensor is fourteen years and 240,000 miles old. Tomorrow when everything opens back up after Christmas I am thinking I am going to call around to find a working used MAF sensor to swap and test. Hopefully that fixes the problem .
Dec 25, 2017 at 8:52 AM
I would not go the used route at all. I would go with a new or re-manufactured unit.
Try it and let us know the results.
Dec 25, 2017 at 8:53 AM
KEITHC21
  • 41 POSTS
Alright thank you very much for the advice. I will pick up a new sensor ASAP and get back with the results soon as I put it in.
Dec 25, 2017 at 11:03 AM
You are welcome. Please keep us updated.
Dec 25, 2017 at 11:09 AM
KEITHC21
  • 41 POSTS
Yes absolutely. Once I put the new sensor in or run into anything new, whichever comes first I will post an update.
Dec 25, 2017 at 11:46 AM
KEITHC21
  • 41 POSTS
Hello I have an update since last time, I have not done anything new to the truck but when I went into town yesterday the check engine light turned off and has not come back on. Tomorrow tho I am going to use my friends garage since it is freezing out and take another look and test the voltage of the MAF sensor again to see if anything is different. I am thinking something had to have changed to make the light turn off.
Dec 28, 2017 at 11:58 AM
KEITHC21
  • 41 POSTS
Oh. Also, my trip into town is about eight miles one way and I was out for about two hours. It turned off when I started my truck after my first stop in town and stayed off since. I am about to head to work tho so we will see if it stays off on my trip to work and back.
Dec 28, 2017 at 12:12 PM
Okay good. It will come back on at some point as nothing has been done to repair it. At that point when the light returns you will be able to continue with the diagnosis.
Dec 28, 2017 at 5:17 PM
KEITHC21
  • 41 POSTS
Yes it did come back on on my way to work. But I get paid tonight so I am going to pick up a new MAF sensor. I will be back with the results.
Dec 29, 2017 at 10:42 AM
Okay, sounds good. Let me know.
Dec 29, 2017 at 6:38 PM
KEITHC21
  • 41 POSTS
So I ended up having to get a new battery as well as this -15 degree weather ruined the old one. So today I pulled the old battery out, put the new sensor in, then the new battery. It is still idling rough but I drove to work and the light has not came back on and performance seems to be a bit better. Yesterday before work I plugged my code reader in just to check to see if there were anymore codes or anything and there was the P0101 of course but also there was code P0102, mass airflow circuit low. I did not really have any time yesterday to mess around with anything so I went to work then last night when I got home from work I plugged my code reader in again and there was the P0101 still but no P0102. But there was also code, P0717, system too lean bank 1. I have not got a chance to plug it in again since I put the new MAF sensor in but i will when I get home from work in a couple hours. Also, I have no misfire codes but it does feel like it is misfiring. I am thinking when I get home I am also going to take a look at and clean out the IAC, ERG valves and the fuel injectors as well. Also I am going to take a second look in looking for vacuum leaks. I am starting to feel like this is one of those things where there is a lot of little problems. But, if there is anything I have not done that you think might be a cause please do let me know I can use all the advice/help I can get.
Jan 1, 2018 at 4:40 PM
Look for vacuum leaks. it could be the cause.
Jan 1, 2018 at 4:52 PM
KEITHC21
  • 41 POSTS
When I first started looking into this I checked for vacuum leaks but i did not spend too much time on it, maybe your right. It could definitely be a vacuum leak, to make this much easier tomorrow I am going to get a fog machine as a “fool proof” way to check for vacuum leaks. It is just hard to really visually check with there being many lines that are not 100% visible. Also, something I completely forgot in the beginning, when starting the truck it kind of kicks as soon as it turns over when the engine is hot. It does not have a hard time turning over or anything just as soon as the engine fires it sort of seems like it kicks back? Only when the engine is hot though. Any idea what the cause of this could be? Would it be related to the rough idle? Or possibly a faulty ECT sensor or something? Now that we are really getting into things a little more about the truck, I live in Vermont. I bought the truck off a guy here towards the end of the summer, he was selling it because he had a shop in the area replace the fuel pump and they overcharged him big time and he did not have the money to pay them. This is only the trucks fourth winter in Vermont as it was originally from Arizona. The guy I bought it from also had all of the seals/gaskets/plugs In the engine and transmission replaced what would now be around 70,000 miles ago. Since I have owned it the only things I have replaced so far are the oil pressure sensor and now the MAF sensor. Tomorrow when I pick up the fog machine I am also going to get all new plugs and replace those as well as check the wires.
Jan 1, 2018 at 11:09 PM
Okay, make sure you remove the oil fill cap to see if the intake is leaking.
Jan 2, 2018 at 2:49 AM
KEITHC21
  • 41 POSTS
Alright, so I removed the oil cap and checked for vacuum leaks with the fog machine, I did not see any leaks whatsoever. Spent a good twenty minutes on it just to be sure. Then I replaced spark plugs and tested all the wires for resistance and they were all good. Something I found a little weird tho is that the old spark plugs, seven of them were gaped 10mm bigger then original factory specs. And one was exactly at factory specs. (0.060mm) the new plugs I got are gaped to 0.040mm tho because there was an update on the factory specs and it is now 0.040mm. It is idling a little smoother now but something still does not feel right. And also I was going to clean out the EGR but I do not think my truck has one, kind of puzzled me at first because I know exactly where they are on these trucks and it is not there, lol. But I did a little research and looks like some model years were made without one. And I could not find the IAC either? I checked where it would usually be on this model truck (on the right side of the throttle body) and it is not there? Any clue where it could be? Or what else could be causing it to idle rough?
Jan 2, 2018 at 2:42 PM
do you have a vacuum gauge?
I will check on the EGR and IAC
Jan 2, 2018 at 2:50 PM
Okay, there is no EGR on this one. There is also no IAC. the throttle body controls the idle speed and does not require the IAC.
Jan 2, 2018 at 2:54 PM
KEITHC21
  • 41 POSTS
No, I do not have a vacuum gauge myself. And, oh alright that is interesting. Hmm, actually what about the camshaft position sensor? Or crankshaft position sensor? Would I be wrong if I said both could possibly be the cause of the rough start and idle?
Jan 2, 2018 at 11:30 PM
KEITHC21
  • 41 POSTS
Just trying to figure out all of the possibilities so I can test/look into whatever else that could possibly be a cause tomorrow. I have the day off work so Ill be spending most of the day trying to figure this out. I just really want it fixed asap as this truck is my daily driver during the winter months and I also absolutely love this truck and I would hate to damage anything else by result of driving it in this condition.
Jan 2, 2018 at 11:36 PM
When either one of those sensors fail, they would code. they will not cause a rough idle. that is mechanical issue. that is why I am asking about a vacuum gauge.
Jan 3, 2018 at 2:31 AM
KEITHC21
  • 41 POSTS
What if they have not fully failed yet but are starting to? I am just thinking like similar with the MAF sensor before I replaced it, it was failing but had not fully failed yet as it was still giving a signal just a weak/incorrect signal.
Jan 3, 2018 at 12:53 PM
I understand but the mass air flow did code.
if they were failing they will set a code.
Jan 3, 2018 at 1:00 PM
KEITHC21
  • 41 POSTS
Oh alright makes sense. Well I will try to find a vacuum gauge to borrow I think advance loans a tools so I will look into that. And in the meantime I am going to check the timing chain as it is probably about time to check that anyways.
Jan 3, 2018 at 1:15 PM
yes, good move. the vacuum gauge will assist you in checking the valve timing. low engine vacuum is an indicator.
yes parts stores have a tool rental program.
Jan 3, 2018 at 1:27 PM
KEITHC21
  • 41 POSTS
Alright well first thing tomorrow I will go down to Advance Auto to get a vacuum gauge and test the vacuum pressure. I will be back with the results from that.
Jan 3, 2018 at 4:54 PM
sounds like a plan.
Jan 3, 2018 at 4:55 PM
KEITHC21
  • 41 POSTS
Hey. also, I was looking around in my engine bay after I went to the store, just taking a second good look to see if anything looked strange, etc., and I noticed that on both exhaust manifolds there is a bolt missing. same spot on both sides, it is on the end closest to the front of the vehicle and it looks like there may be a small gap. Do you think this could be the cause of anything? Would it be a good idea to test if and/or how much air is getting through there with the fog machine? Also I noticed there is no distributor cap/rotor, instead ignition coils. Could the ignition coils be a suspect?
Jan 4, 2018 at 12:34 AM
the holes are normal. the manifolds fit different application. if there was a leak you would hear it and see it. it would be black all around the leak. it would not cause a rough running engine.
Jan 4, 2018 at 1:15 AM
KEITHC21
  • 41 POSTS
I am back. Unfortunately I have not had time for much the last few weeks, almost all of the water pipes in my house froze and burst along with the septic drain line that froze as well and it was all just a big mess. But back to the truck. I did end up getting a vacuum/fuel pressure gauge the other day so I checked vacuum and vacuum was right in the middle of the specified range for my truck. Then I checked fuel pressure, it was a bit lower then it should be at idle and absolutely no pressure when not running. So, I know the fuel pump is good that was just replaced not even four months ago. last week I believe it was, I replaced the fuel filter. And today I replaced the fuel pressure regulator. and it is still idling rough.
Feb 10, 2018 at 4:08 PM
the fuel pump needs to be above the minimum spec at idle and should hold pressure when turned off. this alone tells me the pump is no good.
What was the exact pressure?
Feb 11, 2018 at 12:34 AM
KEITHC21
  • 41 POSTS
Well the last time I checked the fuel pressure was before I replaced the regulator and it was at about 47 psi while running and 0 psi when off. I just checked it again today with the new regulator and now it is still 47 while running. but, now this part seems weird to me this I do not quite understand, as soon as I shut the truck off it stuck at 47 for a second then slowly rose to a perfect 55 and stayed there.
Feb 12, 2018 at 10:45 PM
That is okay, as long as the pressure remains.
did you re check the voltage at the mass air flow? check the signal voltage. the hot wire is the 12 volt signal. check the 5 volt signal return.
Feb 13, 2018 at 1:18 AM
KEITHC21
  • 41 POSTS
Oh okay. No I have not thought to but it does sound like a good idea especially seeing how the MAF was kind of my original underlying cause. I will definitely get on checking that, I will have the results shortly.
Feb 13, 2018 at 6:47 AM
Okay, please let us know the results.
Feb 13, 2018 at 7:21 AM
KEITHC21
  • 41 POSTS
I rechecked the MAF power and Signal wires and power is good, 14.34 volts and signal looks good also at 4.65 volts.
Feb 13, 2018 at 4:05 PM
Okay, now monitor the signal voltage while running. when you rev the engine, the signal voltage should vary. it should change with engine speed.
Feb 13, 2018 at 4:10 PM
KEITHC21
  • 41 POSTS
Sorry it has been so long been very busy with work it is our busy season. But I tested the MAF signal at different rpm's and yes it increases and decreases with rpm.
Apr 2, 2018 at 6:12 PM
Okay, did you check the hose to the throttle body for any leaks?
Also, the connector was an issue. make sure there is no bent, loose or damaged pins. any of the above will cause this code as well.
Apr 2, 2018 at 6:24 PM
KEITHC21
  • 41 POSTS
Yes I did. I also checked around the sides, front and back of the intake manifold along with the vacuum lines to the brake booster and fuel pressure regulator, PCV hoses and around the valve covers. I also made sure the o-rings on the MAP sensor and EVAP purge valve are in good condition and sealed up tight. and yes I checked the pins where the connector plugs in and the connector itself along with the wires and I tested them all for proper voltage and resistance tested the grounds and all is good.
Apr 3, 2018 at 8:51 PM
