Hi Ken, After over 18 months I got my car running today but with a 'slight' problem unrelated to the original issue.
To go over what I have done since I last posted here are the details:
1. Removed oil/gas mixture from engine sump by syringe(!) and filled 5 x 4L containers with this liquid. Engine uses 6.5L of engine oil!!
2. Changed engine mounts for new ones.
3. Ordered used DME/computer from California but eventually found out that it was for an automatic and had part different numbers on the the casing.
4. Added new oil (Amsoil - European blend), 1 bottle Prolong, 2 bottles of Auto-RX for sludge removal and engine cleanup.
5. Sourced another DME/computer unit from Lithuania. Popped it in today and the car started!! Whoopee!
Now to the 'slight' problem.
Fuel is spraying out from the junction between the injectors and the fuel rail (with the subsequent puddle of fuel on the floor again!). That means that I haven't seated the injectors in the fuel rail correctly, which I find a bit puzzling as I couldn't seat them in further. So will be looking at a YT video if I can find one. Do you have any ideas of how far the injectors need to be inside the fuel rail? There are 2-3 notches on the side of the injectors and they are all showing (clips should be around the fuel injectors with the side of the clips seating in these notches. At the moment the clips are around the metal stem at the top of the fuel injector). The rubber O-ring at the top is just barely visible within the fuel rail tube that comes down to meet the fuel injector. I believe they need to by much further in with the first notch on the fuel injector being right near the end of the fuel rail tube so that the clip can sit inside these notches and also be secured to the fuel rail via a slot in the back of the clip. Have I got this correct?
Anyway, I thought you would like to know what happened.
Update: I just watched a YT video (
https://www.youtube.com/watch?v=vrXdlqgs8Io) on removing injectors and I saw right off the bat that my injectors were not pushed in far enough. I have 2 notches showing whereas in the video there is only one notch showing with the other one (closest to the fuel rail tube) being used by the clip to hold the injector in place. So I will get these injectors sorted out tomorrow (Saturday).
Jan 11, 2019 at 1:31 PM
