starter not cranking the engine over?
2001 JEEP GRAND CHEROKEE
150,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
AFRAUSTO94
  • 16 POSTS
As the winter months have come about, I’ve noticed my vehicle has become harder to start. This morning, I went out to start it and it was having a hard time turning over and then all of a sudden you could smell either burnt electrical or burnt rubber and now the vehicle will not start. Any help will be appreciated. Happy holidays. :-)
Dec 1, 2019 at 6:23 AM
Good morning,
Let us start with the battery. Does it crank the engine over fast?
Have you checked anything else like spark and fuel pressure?
Dec 1, 2019 at 8:26 AM
AFRAUSTO94
  • 16 POSTS
Could any of those things you mentioned be related to burnt rubber or electrical smell?
Dec 1, 2019 at 6:25 PM
AFRAUSTO94
  • 16 POSTS
Also, thank you for replying to my question.
Dec 1, 2019 at 6:26 PM
Possible but need to narrow the area of failure first.
You are welcome.
Dec 1, 2019 at 6:38 PM
AFRAUSTO94
  • 16 POSTS
No, it doesn’t crank the engine over fast. We charged the battery last night, put it back in this morning and all it does it click one time.
And haven’t checked fuel or spark pressure.
Will be sure to check when I get off work. :-)
Dec 2, 2019 at 4:09 AM
AFRAUSTO94
  • 16 POSTS
Update: so, when we first went out there to try the charged battery, it clicked once and all the lights inside the car came on. After that we tried it again and nothing at all. Not one click or anything.
Dec 2, 2019 at 4:15 AM
Sounds like you need a new battery. I would replace the battery and go from there.
Dec 2, 2019 at 4:56 AM
AFRAUSTO94
  • 16 POSTS
You’ve got it!
I’ll update you once we get that new battery in.
Dec 2, 2019 at 6:36 AM
Sounds like a plan.
Dec 2, 2019 at 6:42 AM
AFRAUSTO94
  • 16 POSTS
So, I put the new battery on and tried to start it, it started and I looked and none of the pulleys were spinning besides the very bottom one but then I tried again and was watching the pulley in the very bottom one was spinning but none of the others then when I went to take the belt off to put a new one on the belt wasn’t put on the tensioner so I’m letting the battery charge and then going from there. Also, another thing that happened was the drive side window started falling down, I don’t know if it could be related to anything going on. Just thought I would throw that in there.
Dec 2, 2019 at 11:07 AM
Let us get it running first, then we can address the window. It most likely needs a regulator.
Dec 2, 2019 at 11:20 AM
AFRAUSTO94
  • 16 POSTS
Okay, I thought it might have been related to what was going on with the car already, it was just convenient was all.
Also, the “new” battery died, so we charged it again, put it back in and nothing happened. Didn’t start, nothing at all.
Dec 2, 2019 at 11:28 AM
It needs to be charged to 12.6 volts. It should take about 2 to 3 hours to charge the battery.
Dec 2, 2019 at 11:30 AM
AFRAUSTO94
  • 16 POSTS
Update, so we were told to look at the fuses, we took out one fuse “starting relay” was extremely corroded replaced it and started right up.
Went out just a little bit ago and turned off and on twice on the third try it didn’t turn over, didn’t click.
Dec 2, 2019 at 2:18 PM
Go back to that fuse again and make sure the terminals are clean and tight. Then try it again.
Dec 2, 2019 at 2:51 PM
AFRAUSTO94
  • 16 POSTS
The terminals are clean. Put the new battery back in, made a bunch of clicking noises. Tried twice to start it and then on the third it didn’t do anything. It’s like it’s sucking the charge out of the battery. Have the batteries back on the charger.
Dec 2, 2019 at 5:18 PM
What is the voltage of the battery?
Dec 2, 2019 at 5:22 PM
AFRAUSTO94
  • 16 POSTS
I don’t know how to figure that out. All I could find on the battery is cold cranking amps which are 675. I know that’s not what you asked for, I don’t have any tests to figure out the voltage.
Dec 2, 2019 at 5:38 PM
You need to get a voltmeter for some checks. You can get a cheap one at a parts store for these tests.
Dec 2, 2019 at 5:46 PM
AFRAUSTO94
  • 16 POSTS
Okay. Thanks, sir.
I’ll be sure to get back to you once I get that figured out.
Dec 2, 2019 at 6:09 PM
You are welcome.
Always glad to help.
Dec 2, 2019 at 6:44 PM
AFRAUSTO94
  • 16 POSTS
So the batteries are reading 12.84 and 13.13.
Dec 3, 2019 at 11:03 AM
Okay, does it start?
Dec 3, 2019 at 1:16 PM
AFRAUSTO94
  • 16 POSTS
Yes, it does.
Has a little bit of trouble, and one of the pulleys is squeaking.
Dec 3, 2019 at 1:49 PM
Sounds like the idler pulley. Remove the belt and spin it by hand.
What is the voltage at the battery with the engine running?
Dec 3, 2019 at 2:25 PM
AFRAUSTO94
  • 16 POSTS
Okay.
And the voltage of the battery is 14.3.
Dec 3, 2019 at 2:30 PM
Okay, need to find the source of the noise.
Dec 3, 2019 at 2:39 PM
AFRAUSTO94
  • 16 POSTS
Is the idler pulley going to be the one on the right side of the alternator pulley, above the tensioner?
If so, we had just replaced it the other day.
Dec 3, 2019 at 3:36 PM
Yes, it looked like the tensioner was replaced but not the idler pulley.
If it was, remove the belt and spin each component one at a time to find the source of the noise.
Dec 3, 2019 at 4:25 PM
DOUBLEDUCKS
Pretty much desperate for help!
My Dad's 2001 Jeep Grand Cherokee's engine has immobilized itself. We have hooked it to 3 different diagnostic machines, and each one has come up with no result.
We get to first stage ignition but there is no engine turnover and the dials do not move at all. It seems that all of the other electric work, e.g. door open notifications etc..
Please help!
Aug 31, 2020 at 12:46 PM (Merged)
HMAC300
  • 48,601 POSTS
try resetting security system if no manual look online.
BON21354
I turn key and only get 1click I changed starter and battery and check ground wires and still only one click please help
JDL
  • 16,098 POSTS
I would have to check wiring circuits at your starter. Any testing at starter make sure tranny is in park or neutral and the parking brake is set. Check applicable fuses. I would have to be sure battery has a full charge and charging system is ok?
JDL
  • 16,098 POSTS
Just to add, no 6.0 so looked at 4.0L engine. Note the relay, terminal 30 is hot all the time and is fuse protected. When the relay is energized that line with the arrowhead moves to terminal 87 and voltage goes to starter. Also, red wire at starter, hot all the time
The coil side of relay to the left, also needs voltage and ground. I'm not sure about that clkicking noise either relay or starter itself.
Any body else has any ideas, jump in, no problem.
JEEPGIRL
If this is free, why do I have to go through the annoyance of "signing up"? Dumb!
Here's my problem: 2001 Jeep GR CH runs great. Problem been developing over a year. Did not happen every day or even every week. When I turn the key all electrics come on but the engine does not crank. NO noise is associated with this. Usually on the second try it cranks right up no problem! As of 2 days ago it took 5+ tries. Today 5-10 tries with THREE keys all properly programmed at dealer when we bought the car new. Now repair man said "I don't know. Just drive it around and 'call me'(!!)" HUH?!? I think it is the ignition switch because everything comes on when the key is turned. Please help as this is my primary vehicle and I need to be able to travel long distances with confidence. Thanks
JDL
  • 16,098 POSTS
I don't know of any site that will let you post without registering. There are many reasons to have you register. The least of all is to try to control trouble-makers.
With intermittent issues, you have to test when the problem is ongoing. Below is a wiring diagram for your starter circuit. If you have any questions about the diagram, holler. Any testing make sure the tranny is in park or neutral and the e-brake is set.
JANJERA32
We put the key in the ignition(we have two keys) and it feels as if we are forcing it to start. The keys just fall out after we start as if it's not catching all the pins inside. It starts 98% of the time but the dash lights, radio and speedometer don't come on. Also the brake light and ABS come on. Then when we start driving the transmission takes a long time to shift and sometimes the gears grind when changing gears when we go from park to reverse and so on. I checked the fuses I could and there're all fine. Is the the starter or ignition switch or an electrical problem?
CJ MEDEVAC
  • 11,004 POSTS
SOUNDS LIKE YOU MIGHT HAVE MULTIPLE ISSUES
THE "KEY THING" SOUNDS LIKE THE IGNITION LOCK CYLINDER NEEDS TO BE REPLACED (KEYS FALLING OUT)
.....AND MAYBE THE IGNITION SWITCH ACTUATOR (WHOSE HOUSING IS MADE OF PLASTIC...PROBABLY FALLING APART)
...........IT'S ALSO POSSIBLE THE ACTUAL IGNITION SWITCH COULD BE IN THE MIX TOO
ARE YOU GONNA DIY THIS PUPPY?
DO YOU HAVE A REPAIR MANUAL?
I MAY BE ABLE TO GET YOU SOME DIAGRAMS
SOMETHING IS WRONG WITH "ME" GETTING E-MAIL NOTIFICATIONS, I HOPE THEY GET IT FIXED....OTHERWISE I WILL NOT KNOW IF ...ANY...OF THE MANY....HAVE RESPONDED TO ME......THIS HAS BEEN GOING ON FOR DAYS
YOUR TURN (GOOD LUCK)
THE MEDIC
Based on your description, it sounds like the ignition switch itself is going bad and causing the issues. The switch is located on the steering column (about 2/3rds of the way down). There is a steel linkage rod that goes between the tumbler (where the key goes) and the switch. As far as it being tight to turn, try to lube the tumbler to see if that helps. A special graphite grease is made for key tumblers and you can get it at most parts stores.
CHRISTAL1
  • 6 POSTS
So I got a new starter and a battery for my vehicle listed above it is the Laredo model. My battery is from a friend and my capacitor for my system reads 13.8 for the battery. (the old one was 12.4) It started perfectly fine until I hooked up my amp and speakers. When we hooked the system back up it had a rough idle and acted like it wanted to stall. We disconnected the wire and it ran fine again. So we cleaned the ground under the hood and ran a new ground from the system, then hooked the system back up. I started it twice acted fine no rough idle or anything. It started right up both times. After I took someone home and went to the gas station and it was running fine. Idle was normal, drove it for twenty minutes. After I got gas it did not want to start again. Just kept clicking each time I turned the key. I disconnected the system from the wire in the back and still did not want to start. It only started when I got a jump.
When I got home I turned it off and about thirty minutes later I tried starting it again. The first time it clicked so I turned the key off and tried again, it started right up. I had let it run for about ten then turned it off. Tried to start it right away and it did not want to start until last second and it did. Any idea what this is? I have already clean the grounds.
(The system worked perfectly fine before we replaced the starter and battery. It has been hooked up since I first got it.)
Aug 31, 2020 at 12:47 PM (Merged)
