Camshaft sprockets removal instructions
2000 KIA SPORTAGE
149,000 MILES • 2.0L • 4 CYL • 2WD
JCLEMO
  • 161 POSTS
Does anyone know where I can buy the tool that holds the camshaft sprockets while replacing the timing belt? I can't seem to get the valve timing just right so I got starting issues. Either one or the other of the two gears seems be out a tooth. I can't hold both gears and put the belt on at the same time without one of the cam gears turning on me just enough to mess up timing. So I'm looking for the name of the tool and where I can buy it?
Probably Amazon slowing shipping in the world and they charge you on top of that. Any information greatly appreciated
JC
Jun 29, 2019 at 5:47 PM
Hi JCLEMO,
Normally, overhead cams have a holding tool but this one does not. I included the procedure. I suspect you are having an issue on Step 3 where it says to install the belt so that there is no looseness on the tension side. If this is not done then the cams will move.
Look over the process and let me know if you have questions. Thanks
Jun 29, 2019 at 6:12 PM
JCLEMO
  • 161 POSTS
Which diagram should I be looking at? I've had this belt off and back on five times today and I don't see anyway of keeping these from moving if but just one tooth enough to mess things up.
Jun 29, 2019 at 6:22 PM
He posted the entire procedure for replacing the belt.
You have already done that procedure. The marks are the same as I posted on out other question.
Check with NAPA, advanced, AutoZone and Pep Boys for the tool.
Jun 29, 2019 at 6:24 PM
JCLEMO
  • 161 POSTS
Yes I know, I don't know why he felt I needed to refer to the photos. I know the problem I just need the tool to hold these gears from moving it's just that simple.
For some reason one side wants to move before I get everything lined up and locked down.
Jun 29, 2019 at 6:29 PM
That is because there is too much slack in the belt. With the tensioner installed. there should be no slack at all.
Jun 29, 2019 at 6:37 PM
Guys,
There is no tool. I posted the entire procedure so you can follow it in the event you need it.
Here is a video on how to do it: You can try to find a tool if you want but I doubt one exists because the service manual doesn't tell you to use one and I have never seen anyone use one.
https://youtu.be/aEnidrPB10g
Jun 29, 2019 at 6:45 PM
JCLEMO
  • 161 POSTS
There's no slack in the belt now. but I'm still of a tooth off and every time I take the tension out of the belt and try to turn the cam back or forward a tooth it's not loose enough. so I take the whole belt back off and right back to square one. I'm going to Harbor Freight and try to find the right kind of tool to fit this thing I don't have a clue what I'm looking at. But have no help I mean physically help to hold a socket on it while I do the belt
Jun 29, 2019 at 6:46 PM
You can slide the belt forward of the gear and move it the tooth and slide it back on.
Jun 29, 2019 at 6:48 PM
JCLEMO
  • 161 POSTS
That's something I watched this same video four times today. And you see how he has two ratchets one on each cam gear? I suspect there is a trick to it or someone held the ratchets while he installs the belt I don't remember. But there's also a video of a guy using the tool I'm talking about in a demo of a dual cam motor timing belt change. I'll go back watch the video again maybe I missed something but this has been a nightmare. Two more hands I could do it.
Jun 29, 2019 at 6:54 PM
I understand.
Jun 29, 2019 at 6:56 PM
Correct. He is using two ratchets so he can hold it in place while he is installing the belt. They flash on the screen to wedge a screwdriver behind the sprocket to hold it in place. I have seen this done and they damaged the backing plate so be careful if you are going to do it. Each time I do it, I do have someone holding it so I get your pain trying to do it by yourself.
Jun 29, 2019 at 7:00 PM
JCLEMO
  • 161 POSTS
Yes, I made the mistake of putting a wedge of wood in front the gears and like to have never got them out. I have been bent over this thing like ten hours. And it starts but when I turn it off and align the timing by hand and a ratchet on the crank when I rotate by hand back to the marks it's usually the intake camshaft is out by a tooth. Every time so it's hard starting.
Jun 29, 2019 at 7:07 PM
Sometimes it is best to walk away and come back with a fresh mind tomorrow.
Jun 29, 2019 at 8:12 PM
JCLEMO
  • 161 POSTS
Very true.
Jun 30, 2019 at 4:03 AM
Keep me updated.
Jun 30, 2019 at 5:11 AM
JCLEMO
  • 161 POSTS
I'm almost 70 years old so it takes me a while in the mornings but I'll get at it in a bit. And I can't tell you how much I appreciate all your help and what a great job you guys do and to take your time on the weekend to respond to these questions really shows your commitment to your work and this site as well. Great job thank you again and I will let you know how things go today.
I'm going to try again and if I have no luck I'll look for the cam tool. Have a great day.. JC
Jun 30, 2019 at 5:20 AM
You are welcome.
We are always glad to help.
Jun 30, 2019 at 5:27 AM
JCLEMO
  • 161 POSTS
I got a question for you.
When bringing your cam gears upon the backing plate marks if you aren't very careful the gear will jump forward past the mark and you hear a loud click. Why is that? I'm guessing it's an indication the valve or valves have either opened or closed. And when your marks are aligned properly in what position are the valves under the cylinder? My son is coming all the way across the state from East coast today to hold the ratchet for me. I hated to ask him to do that but I live deep in the country pretty isolated so it's really my only option. I really hope this works and that this is the problem. It ran fine when I parked it and decided to change the belt. The bad thing is the belt looked fine but I didn't like the looks of the tensioner. Okay, thank you.
Jun 30, 2019 at 7:22 AM
Yes, the clicking is the movement of the valves. It will not do it when it is spot on alignment.
Jun 30, 2019 at 7:33 AM
JCLEMO
  • 161 POSTS
Gotcha just wanted to make sure. Got everything lined up perfect waiting on my son .. everything has to be just perfect I can see that now there's no room for error at all, but I think with another pair of hands I'll be okay.
I rebuilt my Nissan hard body last year whole engine with no trouble.
Jun 30, 2019 at 8:33 AM
Good.
Keep me updated.
Jun 30, 2019 at 8:37 AM
JCLEMO
  • 161 POSTS
Hello Roy, I got the timing right finally, starting up like it should. what I had to do was loosen the belt enough to turn the crankshaft back to 12 o'clock position and that made the difference. But I've really got major issues now. I don't know how this happened but the car was at an idle and low and behold the belt jumped off. So I don't have to say anymore because you know the results. Heads re-manufactured is $800.00. Not going go there. do you have any idea what it cost to replace the valves that are bent ? Because the rest of the head should be fine being it didn't run hot. Thanks. JC
Jun 30, 2019 at 6:16 PM
If you pull the head around $500.00.
Jun 30, 2019 at 9:06 PM
JCLEMO
  • 161 POSTS
Wow. I think what happened was a little antifreeze ran down the block from the thermostat housing or where it goes. It was not on the motor yet and of course it's very slippery. So I suspect it ran down onto the crankshaft gear and caused the belt to run off the pulley. Is there anything a person can use to clean that stuff off?
I'm going to put another belt on it today and see if it will start at all. If not I'll pull the head maybe replace the bent valves. And hope their not all bent.
I thank you for all your help. JC Hope you have a good week.
Jul 1, 2019 at 1:19 AM
Did you have the harmonic balancer on when you started the engine?
Jul 1, 2019 at 6:37 AM
JCLEMO
  • 161 POSTS
Just wanted to update you on the timing belt on the Kia. No damages were done when the belt came off due to the antifreeze getting on the pulley.
I put a new belt on this morning. And started right up multiple times. All glory to the Lord. And the great mechanics at 2CarPros.com. Thanks again.
Jul 1, 2019 at 6:38 AM
JCLEMO
  • 161 POSTS
No I did not.. I just wanted to make sure it would start first.
Jul 1, 2019 at 6:39 AM
JCLEMO
  • 161 POSTS
Maybe now would be a good time to do that.. Right?
Jul 1, 2019 at 6:40 AM
Okay, that's why it flew off not the coolant.
The belt will try to move forward when running it with the balancer.
Jul 1, 2019 at 6:43 AM
JCLEMO
  • 161 POSTS
Oh okay. I had nothing to hold on it just walked it's way off the pulley. Luckily it was at an idle.
Jul 1, 2019 at 6:47 AM
JCLEMO
  • 161 POSTS
So I started it twice this morning back to back no problems so should I put the balancer back on before starting it again I would think so after what you told me. So I just learned a very important piece of information this morning. Thank you I will start putting the balancer back on. What's the odds of no damages in this situation Roy?
Jul 1, 2019 at 6:52 AM
Do a compression test to verify. You need around 130-150 on all cylinders.
Jul 1, 2019 at 6:53 AM
JCLEMO
  • 161 POSTS
Okay, you think that motor has that kind of compression with 150,000 miles on it?
Jul 1, 2019 at 6:55 AM
It should, yes.
Jul 1, 2019 at 7:03 AM
JCLEMO
  • 161 POSTS
Okay, I'll probably put everything concerning the timing belt back together. Because this new project is all top end only. But I do agree it's a good idea that way I know exactly what I got.. It may be I need to trade it in. I don't think I've got a rering and new bearings in me.. To much work. But then again just taking that head off is too much I think for me that is. Thanks. JC
Jul 1, 2019 at 7:18 AM
I understand. it is still cheaper to fix it than trade in the car.
Jul 1, 2019 at 7:38 AM
JCLEMO
  • 161 POSTS
You think so? I wish you were local mobile mechanics or any mechanic.
Around here are expensive. But then again you guys earn every penny that's
fact. I got a price on fixing this several months ago at around 700 dollars.At
The time I wasn't aware of dual cam situation. I have done chains in the past and belts and never had this much
Difficulty. So I figured I'd save myself some money and give me a project to
stay busy too. But had I known this I
think I would have given him the job.
Jul 1, 2019 at 7:50 AM
A used motor would cost about $3,000.00 to install.
Can you buy a new car for $3,000.00 ? That is almost sales tax on a new car today.
Jul 1, 2019 at 8:04 AM
JCLEMO
  • 161 POSTS
Yes I would never buy a new car couldn't afford the payments if any thing I'd just trade it in and get what I could $500.00. Probably and put $500.00 with it and buy . Three thousand dollar used vehicle. I can get $400.00. From the salvage yard. Hate to do that it's in excellent condition .
Jul 1, 2019 at 8:55 AM
Think about it before you pull the trigger.
Jul 1, 2019 at 9:02 AM
