It is possible that the security malfunction message and the "Starting Disabled, Please Remove Key" message you are seeing on your Cadillac Seville are related to issues with the vehicle's anti-theft system. However, the cost of repair can vary depending on the specific cause of the problem and where you have it serviced.
In many cases, this type of issue can be related to the PassKey or PassKey II anti-theft system used in older Cadillac models. These systems rely on a transponder embedded in the ignition key to communicate with the car's immobilizer system. If there is a problem with the key, the ignition cylinder, or the anti-theft system itself, it may prevent the vehicle from starting.
The cost of repair will depend on what component is causing the issue. If it is related to the key or ignition cylinder, the cost may be lower compared to a problem with the immobilizer system, which could involve more complex diagnostics and programming.
Jul 6, 2020 at 2:05 PM
(Merged)
