Intermittent stalling
1993 BUICK CENTURY
179,000 MILES • 6 CYL • FWD • AUTOMATIC
TAT24U
  • 5 POSTS
well at least the IACV is the cheaper of them but i will keep you informed its just its parked like 30 mins from me so i got to rely on rides sorry
Feb 15, 2019 at 7:07 PM (Merged)
THOMAS32
  • 24 POSTS
Just to see if it runs it starts fine now but pushin on throttle will not let me roar the engine do u think it will run right for now or go agian and buy a Cadillac converter
I'll be waiting for your return
no, without the sensor there is no fuel control.
THOMAS32
  • 24 POSTS
So what's next buy cat converter replug the sensor back up and it'd start but still will not hold
I really dont know. going on what you have said, it may or may not be the issue. we are guessing here from info provided. before you spend hundreds of dollars on a cat. you should have someone verify our findings.
S BENEDICT
Dies when traveling 50mph and also when idling and I put car in neutral. Will start back and run fine for 2 or 3 hrs. then die again. I have a delivery route so alot of stop and go. Mechanic checked out (fuel pressure ect) and drove it but car ran fine. Had this same problem 2 weeks ago died twice then ran fine and I assumed it was bad gas since it ran 2 weeks with no problem. this week it started acting up again. I just replaced both wheel bearings and a sensor so I would like this resolved. Hopefully you have a idea whats wrong.
THOMAS32
  • 24 POSTS
Ok can I try and drive it to auto zone and get a trouble code
check the fuel pressure. it may be a pump failing
GEORGE MORRISON
I have a buick centery wagon that will run, but every time i come to a stop the car will cut off. I would like to know what is causing the problem. I have replace the crank sensor, i replace the cam shaft sensor. I had the electronic module check and it was good. I also replace the core packs. tell me whats next, the computer.
Hi george morrison, Welcome to 2carpros and TY for the donation
Try disconnecting the TCC solenoid and see what happens don't work, clean out the idle air control valve and EGR/PCV valves and test the throttle positon sensor
