[quote:f12d1fcea7="KHLow2008"]Hi again
Glad that I have been of help.
Chicken or egg is true.
The clutch locks when the compressor is required to work and unlocks when the desired cooling temp is attained or during hard acceleration.
When the clutch engages, it tends to slip before it fully engages and over a long period of time, the wear will create a bigger clearance gap between the plates. This will result in in partial engagement of the clutch and heats builds up when slippage occurs. This will fry the coil.
Fixing the clutch might have protected the coil but then again it could have been the other way round. The strength of the coil diminishes due to old age, poor wire connector contact or oil getting between the coil slowly shorting it. This will cause improper clutch contact.
The alternator failure should be just coincidence because even if the coil is shorted, the fuse will blow protecting the alternator, unless you have installed very high amp fuse which will cause the alternator to give way before the fuse blows.
Just remembered, maybe the alternator was not producing enough current so the coil got affected.[/quote:f12d1fcea7]
Hello, KH:
Again, thank you for your helpful responses.
Now that I think about it, the a/c was not blowing cool air several days BEFORE the battery light went on.
If the alternator and the a/c probems are related, is it, more likely than not, that the battery light would have come on at the same time as the a/c problem?
The battery was not replaced -- only the alternator.
Aug 25, 2020 at 12:48 PM
(Merged)
