1994 Acura Integra oil disappearing?
1994 ACURA INTEGRA
175,000 MILES • 4 CYL • FWD • MANUAL
CBORDEN
  • 29 POSTS
what does that mean?
May 31, 2010 at 5:37 PM
CBORDEN
  • 29 POSTS
no smoke coming out of the oil fill up someone told me my tps sensor may be messed up since when i turn on my car the rpms go up and down over and over again
May 31, 2010 at 10:21 PM
KHLOW2008
  • 41,814 POSTS
If the idling speed is surging, it usually is caused by vacumn leakages, faulty Fast Idle Thermo Valve ( FITV ), Idle Air Control ( IAC)valve, idling speed set too high, lack of coolant in system or cloggecd coolant hoses to the IAC and/or FITV.
The TPS is less likely to be the cause.
Jun 1, 2010 at 7:28 AM
CBORDEN
  • 29 POSTS
ok so no smoke was coming out of the oil fill up so what next ?
Jun 1, 2010 at 9:43 AM
KHLOW2008
  • 41,814 POSTS
How is the oil level now?
How many miles have you travelled?
It is surprising that the oil is disappearing with no visible signs an plausible explanation.
If you have not travelled much yet, mark the oil level and monitor the situation for a while to reconfirm the amount of loss.
Jun 1, 2010 at 10:21 AM
CBORDEN
  • 29 POSTS
it was at the half mark i went to a resturant to pick our food up and took it real easy didnt go over 4000 rpms came back checked it and it was just above the bottom dot
i honestly believe its comin out of the exhaust the ground behind my car turns black after so many starts i believe the rings need to be replaced nothing else makes sense to me
Jun 1, 2010 at 2:41 PM
KHLOW2008
  • 41,814 POSTS
With so much oil disappearing, it is a wonder the exhaust is not smoking like a fogging machine. If you run the engine for less than 30 minutes, then it is possible the smoke would not be that much.
If the exhaust is black and oily, then yes, the oil is getting to the exhaust and it could be the oil rings.
Jun 2, 2010 at 9:20 AM
CBORDEN
  • 29 POSTS
i just want to cover all my bases so i bought some rings and imma change those because it will probably need them soon if not now anyways
it obvious it not smoking much cause i dont notice it but i just cant help but think about how a big black stain got on my bumper on the sid eof my exhaust i just hope that this is it cause im tired of spending money on things that may solve it and most of this stuff aint cheap!
Jun 2, 2010 at 1:50 PM
KHLOW2008
  • 41,814 POSTS
Possible causes for oil disappearing are :
1. Worn Valve seals.
2. Oil leaks.
3. Piston rings.
Apart from the above, there are no other possible causes.
Jun 3, 2010 at 8:07 AM
CBORDEN
  • 29 POSTS
ok i believe i found it
while i was takin my engine apart and got down to my pistons i decided to clean the back of my block and when i was doing that i noticed some sort oil catch tank and i also noticed it wasnt bolted down at all just chillin there for no reason
and i remembered when i was taking my intake bracket off that i took out a few bolts on the back side i guess i didnt notice that one was supposed to go back in that so its been loose the whole time just drainin my oil everytime i drive
that makes sense to me how i lose so much oil everytime i drive and i dont see no smoke or nothin
so i believe i found it once i get my car all put back together ill let you know if that was it or not but i strongly believe that was it
Jun 11, 2010 at 1:01 PM
KHLOW2008
  • 41,814 POSTS
That is the blowby box and certainly would be draining your engine oil with not much signs under the vehicle a the oil would be dripping onto the ground.
Hope this solves the problem.
Good luck.
Jun 18, 2010 at 6:00 AM
