Those are D1-D6 on the pin diagram. 2 of those are already in your truck so make sure they get attached there as well as to the "new" wiring as needed.
That came out of a truck with power seats. That is what the second orange wire feeds.
Black with white stripe gets connected to the same wire in the plug you have, it is for the 4wd light.
The orange next to it doesn't get connected it feeds power seats.
The next orange is the power door lock feed.
Yellow is for the power windows
Empty spot is for rear door release on Blazers/Subs.
Last black is a ground for the doors, windows, 4WD indicator. It will connect to the grounds coming from the doors and the indicator ground in the original connector so make sure that wire gets connected as well.
BEFORE you plug it in test all the functions first. You can take a 12 volt battery, connect it to the black ground wire and the yellow to test the power windows, Then move the positive feed to the orange feed and check the power locks.
Much easier to correct problems now than to fry the electrics in the truck.
Jan 12, 2017 at 6:44 PM
