all of a sudden the truck acted like the engine shut off?
1991 MAZDA B2600
137,000 MILES • 2.6L • 4 CYL • 4WD • MANUAL
WAYNE PEDERSEN
  • 4 POSTS
The fuel pump seems to be pumping good pressure.Where exactly would I find the relay and how do I check injector pulse?
Mar 20, 2019 at 12:20 PM (Merged)
RASMATAZ
  • 75,992 POSTS
Disregard the fuel pump relay and check and test the circuit opening relay, for the injectors look for power on the injector harness one of them should have power and also use a noid lite.
WAYNE PEDERSEN
  • 4 POSTS
1993 Mazda b2600
Will turn over fine but dies rught out.Changed fuel pump and filter.Seems to be getting good fuel pressure.Will stay running longer when I spray starting fluid in throttle body but still won't stay running.Need some ideas on what else I can try.
RASMATAZ
  • 75,992 POSTS
What is the pressure reading? Also check the injectors if they are pulsing.
JAXXXON
  • 15 POSTS
1989 b2600i 4x4 manual trans. No spark at coil. See prev question and answers from January this yr. Well... I've tried everything short of hiring a voodoo priest. Is it possible that a bad or going bad fuel pump could kill spark at the coil? Thanks!
RASMATAZ
  • 75,992 POSTS
Sounds like the ignition coil or fuel pump problem. Check these links
and
let us know
JAXXXON
  • 15 POSTS
Thanks for the info, it was a bad fuel pump causing the problem, thanks 2Carpros.com
DIAMOND JACK
distributor gets hot and dies wont start back right away sometimes it runs for a long time with out dying changed out distrbutor and it runs about 30 seconds when it was cold ran perfect yesterday when installed reman distributor do you think it might be a computer problem
MHPAUTOS
  • 31,937 POSTS
Sounds more like a power wire part shorting to earth and causing the module to over heat, check the wiring first.
SCOTT HANKEMEIER
Just FYI, 91 Mazda B2600i. Randomly dies, no spark. Sits 10-20min starts up and runs again. Distributor pickup is very common and was the problem. Its the hall or optical sensor in the distributor. Replaced distributor. Common on all the b- series 86-93. Carb models you can get just the pickup or ignitor I think it's called sometimes. Also mine had idle surge/hang at 2k, hard or no start, fuel smell, no power at all, won't Rev up much, flooding out. That was the coolant temp sensor, walker has a sensor with connector. That fixed it.
Feb 10, 2023 at 9:48 PM
Thanks Scott!, I moved this post to the front page!
Feb 11, 2023 at 1:45 PM
