stalled while driving
2016 NISSAN XTERRA
190,000 MILES • 4WD • AUTOMATIC
CM_2310
What kind of petrol is best for my car? Leaded or unleaded?
Apr 18, 2019 at 1:38 PM (Merged)
MHPAUTOS
  • 31,937 POSTS
Do you have a cat converter fitted? unleaded with upper cylinder lube should be fine.
BIGDDCDR1
I've been trying to find the problem with the front end of my pickup.
The problem is a rattle that goes away when the brake pedal is depressed. I was told that it may be a suspension problem, so I replaced the sway bar bushings, the sway bar end links, and the struts.
Last Sunday, I replaced the brake rotors and pads. The rattle went away until Friday, and I heard a faint sound of the rattle again, and it has gotten worse since.
i would look at the pad mountings and make sure they are tight in there mounts.
