ok that clears that up... im a student at uwmilwaukee and was talking to one of my classmates thats had the same issue. He mentioned i could do something with a tech 2 scanner. something to do with;
"unplugging the harness at the base of the lock cylinder, then hooking up the tech 2, going to the special functions options section under I P then run the 10 min. relearn After its done leave the harness unplugged start the car and this will program the system leaving the lock cylinder out of the picture. Dont plug it back in. The only downfall is the theft system is no longer there."
so before i even attempt such a task id rather get the opinion of a certified technician. does this seem logical?
and when you stated module.. are you referring to the ICM? why would that throw a anti theft light?
i dont want to start throwing money blindly hoping the next fix should be the remedy without knowing for sure. thank you again.
Jul 30, 2020 at 5:13 PM
(Merged)
