I still don't have the stem piece removed from the ignition cylinder socket. I'm not exactly clear on how the green clip (looks more like a green plate) is removed, or how to remove the metal plate behind it(?).
I have been wondering if the truck might be able to be restored to regular functioning. I ordered another new ignition switch/key assembly. I'm not sure what went wrong on the first try, but I'm wondering if the truck can be made to work normally. I will replace the shift interlock first (also I could use your comments on the shift indicator cable mount piece which popped out of place, I don't know where it goes back into).
If you can provide just a few more details on removing the stuck stem piece I would appreciate it. And I'll check in afterwards. Again thank you all very much..
Jul 17, 2020 at 10:10 PM
