I have a steering issue I've been throwing parts at for about a year now. A Napa shop had it a month and couldn't find it.
Basically what is happening is intermittently my ESC active toggles on around curves and when it does it seems as if it's coming on thinking I'm sliding off the road because the power steering module assists against me and the abs applies pressure to certain wheels.
The question is why?
I could make a list of everything i have changed and you'd laugh. Most recently I realized that my rear twist beam bushings were bad so I assumed that around curves the rear end was skating causing the ESC active to come on.
Replaced that also and it still does it.
Keep in mind it has never thrown a code for this. Just an intermittent ESC active, not service.
I have been reading about yaw sensors and it seems it possible that it could cause such an issue.
Do you think I'm on to something? If so, I cant seem to find any way to test or read data from it. So how do I test it?
Any ideas on how I finally can figure out whats causing this?
Aug 10, 2019 at 10:57 AM
