Yaw rate sensor location needed
2008 FORD ESCAPE HYBRID
143,000 MILES • 2.3L • 4 CYL • 4WD • AUTOMATIC
KHALID1984
where i can find the yaw rate sensor in the vehicle listed above?
Apr 6, 2021 at 7:57 PM
STEVE W.
  • 15,113 POSTS
It is under the center floor console. You remove the center console and it's bolted to the floor. Slide the seats forward and remove the two rear bolts on the console, then move them back and remove the trim ring around the shifter. Remove the storage bin and upper finish panel, now remove the remaining bolts and remove the console.
What issue do you have telling you there is a problem with the sensor block?
Apr 6, 2021 at 10:03 PM
GIUGGIOLA
I can’t find the sensor I already looked what other part can I find it?
Mar 30, 2026 at 8:08 PM
STEVE W.
  • 15,113 POSTS
That is where it should be in that vehicle. It is put there so it gats better data. Do you have the same year, make and model?
Mar 30, 2026 at 8:14 PM
