Accidentally fueling your vehicle with E85 instead of Unleaded 87 can lead to potential issues due to the differences in ethanol content and combustion properties between the two fuels. Here's some advice on how to proceed:
1. Do Not Drive:
If you've realized that you've fueled your vehicle with E85, it's best not to drive the vehicle until you've taken appropriate steps to address the situation. Running the engine with the wrong fuel could lead to poor performance, reduced fuel efficiency, and potential damage to the engine components.
2. Do Not Top Off:
Adding Unleaded 87 to the E85 in an attempt to dilute the mixture is generally not recommended. The ethanol content in E85 is significantly higher than in regular gasoline, and trying to dilute it may not effectively address the issue.
3. Contact a Mechanic or Towing Service:
Your best course of action is to have the fuel tank drained and refueled with the correct fuel. Ethanol has different properties compared to gasoline, and using E85 in an engine not designed for it can potentially lead to damage over time. Contact a mechanic or towing service to have your vehicle taken to a repair shop or dealership.
4. Visit a Repair Facility:
Once you've had your vehicle towed to a repair facility, they can drain the fuel tank of the E85 and ensure that any remaining fuel lines and components are properly flushed. It's a good idea to consult with a professional mechanic or the dealership's service center to assess the situation and provide guidance on any additional steps needed to ensure your vehicle's proper operation.
Sep 2, 2023 at 6:18 PM
