Wrench light and check engine light after new battery?
2018 FORD FUSION
125,000 MILES • 1.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
KJAMMAMA1221
My husband originally replaced my water pump. After getting everything back together, the next day the battery was completely dead. Changed the battery wrench light and check engine light came on. Next day car wouldn't start without a jump. When trying to turn my car off, the engine kept running even though it had been shut off. It ran for a minute, shuttered, then shut off. We did a BMS and replaced some relays since the code reader said they were bad.. still have a wrench light and check engine with the engine not wanting to shut off immediately after I push the button to turn it off.
Mar 14, 2026 at 10:51 AM
CANNON1349
  • 861 POSTS
Hello, if there is a wrench light on, usually that is indicative of Limp Mode being activated. But there should also be codes stored in the memory that will give a clue as to why this is happening. Please post the codes here so we can assist you better.
William
Mar 15, 2026 at 7:00 AM
