So you do not have a 4.6 liter as listed in the 1st posting?
You have a 258,
These new age people are set on calling it a 4.2 liter.
This is so impersonal to the Jeep and any other vehicle of yesteryear.
When it was made, it was a 258, I use that term in talking and when I buy parts. I even correct the salesperson when they try to "you mean 4.2?"- Nope a 258!
So far things you say or what I can see in your pics is pointing towards the ignition switch as nothing seems to look wrong.
I always try to justify a "blind" parts replacement.
This time, this is the most probable problem, it's maybe 40 years old and the internals of it are probably severely worn and no longer staying in their meant positioning.
pic 1) When I made my '78 into a fully EZ reversible toggle switch and push button run and start (eliminating using the key switch) I took the old switch apart and soldered wires to it- thus using it as a connector for my modification. Never cutting and splicing the original Jeep wires.
This is the internal crap that could mess up in the pic, with the switch taken all apart.
In your case, $20 would be a real easy fix! You could even call it preventative maintenance if we are wrong!
pic 2) This just 2 of several other brands at Advance Auto Parts. I'm showing you in the pic that there are 2 different switches. One for "tilt steering" the other for a "standard column". You must use the correct one!
Your switch is on top of the steering column on the other side of the dash. Getting to yours will require a little of being a contortionist.
I'm showing you this Ford truck just so you will understand how it works, not a way to remove yours! Notice the rod that actually makes the switch move and where it goes. It will be difficult to see and do on the Jeep! See FRIDAY, JULY 1ST, 2011 AT 6:39 AM in this post.
https://www.2carpros.com/questions/1989-ford-bronco-ignition-issues
pic 3) My '77 CJ-5 Knelt down on the ground/ Driver's side/ this is the driver's side of the column/ a 5/16 wrench/ 2 screws.
I'd start with the key being off, carefully remove the switch, do not let it slip up or down the column, we want the "position" of the switch to remain in the "off" position.
Once removed, look at the "rod hole", put the new switch's "rod hole" in the same position as the old one. Reinstall the switch, put the rod in correctly, install the connectors.
There are 2 separate wire connections to this one switch (pic 4) Black and a white. See the detents you have to push in on the sides to release the connectors.
I discussed my push button up above
It's a little complicated.
Just so you can know and grasp it
https://www.2carpros.com/questions/question-for-cj-medevac
For now,
Keep it simple, put it back OEM, save modifications for when you have a healthy Jeep!
Keep me posted or any questions.
The Medic
Nov 24, 2019 at 5:53 PM
