Car started with stalling put a couple times at low speeds/idle. doesn't seem to respond to gas pedal being pressed most of the time. Loud popping sound from engine compartment. Have replaced every component on throttle body the apps sensor AIC, and TPS. Still stalling out after starting. wont even run for maybe a couple seconds then rpm's get low and it does repeatedly.this is only car so what to check next would be greatly appreciated. thanks
Dec 4, 2019 at 12:53 AM
