Five error codes, will not stay running
1991 CHEVROLET LUMINA
207,396 MILES • 3.1L • V6 • 2WD
JIMMY DAVIDSON
Will not run right. Got codes 23,42,34,33,44. I just changed the minigolf gasket because it had a major vacuum leak and would not idle. It seemed to run okay for about thirty miles. I have been trying to fix this car for over a year. Also, occasionally when the check engine light is on and it is running really bad the speedometer does not work.
Aug 16, 2018 at 10:58 AM
STEVE W.
  • 15,113 POSTS
With that batch of codes I would look at the wiring around the intake. Easy to pinch or get a wire in the wrong spot and have it short out.
Aug 16, 2018 at 11:38 AM
