So my wires from my alternator and starter to my battery fell onto my EGR valve pipe 3 times with the last causing a small hole to be burnt into the pipe. The car made it home i turned it off and since then its ether cranked but no start or nothing. i have replaced all the wiring from starter and alternator the crankshaft camshaft ignition coil fuel rail harnesses the MAF sensor crankshaft position sensor every single fuse and relay under the dash and hood the plugs and wires the battery the starter the alternator and still nothing. when using a test light nothing under the dash in the fuse box lights up and under the hood in the relay spots only one area in some none in others lights up on the other side the big fuses all but the 1st 2 light up then below that the 1st 6 light up on both sides but the last 5 nothing and the single fuse by the relays f64 nothing. what more can i do to get my car going again? i just barely taped my horn and it went off uncontrollably to where i had to unplug it. i am at a loss what do to do.
Sep 30, 2019 at 4:43 PM
