won't start, no fire to the sparkplugs
1990 BUICK ELECTRA
128,000 MILES
CHUCK EVANS
  • 16 POSTS
I've got a 1990 Buick Electra that won't start it turns over good but I'm not getting any fire to the sparkplugs. I checked the wires and fuses and they're ok and I've changed the crank sensor, but still not getting any fire, what should I check next? thank you for your help!!
Oct 17, 2013 at 9:04 PM
CHUCK EVANS
  • 16 POSTS
also the only code that came up was 12 so no help there.
Oct 17, 2013 at 10:16 PM
HMAC300
  • 48,601 POSTS
check your fuel pressure at rail. should be 41-47 psi
Oct 18, 2013 at 6:39 AM
CHUCK EVANS
  • 16 POSTS
it's got good fuel pressure
Oct 19, 2013 at 9:19 PM
HMAC300
  • 48,601 POSTS
then check yoru ignition module auto parts can do that , check all your fuses in dash like ign, ecm etc. if fuel pressure isn't with in specs I gave you it's not good
Oct 20, 2013 at 6:43 AM
CHUCK EVANS
  • 16 POSTS
k thank you!
Oct 20, 2013 at 3:29 PM
