Will not start in cold weather
2009 SUBARU FORESTER
168,000 MILES • 4WD • AUTOMATIC
ALIBET15
My car will not start in the cold after sitting overnight. It’s fine once jumped and I drive for a bit. I already installed a new alternator, battery, and cleaned the battery terminals, there is no corrosion. Nothing seems to fix this issue. Anything about freezing it will start fine.
Dec 2, 2019 at 12:10 PM
When you say it won't start, do you mean it cranks and won't start or it does nothing at all?
Dec 2, 2019 at 6:45 PM
ALIBET15
It cranks. It sounds like it’s trying to turn over but just can’t without a jump.
Dec 3, 2019 at 12:55 PM
Make sure the ground between the battery and engine block is tight. You mentioned the battery is good, but check the other end. Also, does it start right away with a jump or is still a delayed start? When if first starts, is it smooth? Is there any smoke from the exhaust that may indicate a fuel related issue?
Dec 3, 2019 at 7:07 PM
