Will not start after battery change
2008 FORD C-MAX
106,000 MILES • 1.6L • TURBO • 2WD • MANUAL
CBESANT
Hello, I hope someone can help me on here. I have the car listed above (TDCI), the battery has been on its way out for a while now and we have had to jump start it a few times. So I changed the battery today but it still will not start. It is turning over now, I think it is a fuel issue, or I need to reset something.
Can anyone help?
Thanks, Chris
Feb 17, 2018 at 11:14 AM
Do you have a security light flashing when you crank the car over?
Please let us know
Feb 19, 2018 at 11:32 AM
CBESANT
The security/immobiliser light flashes when you get in the car, but once you turn the key to the second position it goes out and stays out when the car cranks over.
Feb 19, 2018 at 11:43 AM
Okay thanks, lets start by running he codes to see what come up please follow this guide to see what comes up.
Feb 20, 2018 at 11:54 AM
CBESANT
I did have eleven fault codes come up when I plugged my obd2 scanner in. I cleared the faults on the ECU hoping this would fix it but it has not. There is only one fault code left when I checked again 'P0193'.
Feb 20, 2018 at 12:09 PM
Ya, yes the old fuel pressure circuit high code. Sounds like you need a new fuel pressure sensor. Here is a diagram to help you see how to do the job.
The sensor location should be up by the fuel rail.
Please let us know
Feb 20, 2018 at 4:55 PM
