Engine shut off while driving and will not start
1996 FORD FALCON
1,300 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
TERRY CLARK
Engine stopped while driving. Now will not start, fuel okay, replaced ignition coil still no go.
Oct 18, 2018 at 10:27 PM
First, we need to confirm that fuel pressure is within the manufacturer's specs and it is getting spark to the plugs. If both are good, then confirm there is an injector pulse. Here are links that show how to do all three. This model is not offered in the US, so I do not have the specific specifications for it. However, the tests are standard for just about any vehicle.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Perform these tests and let me know what you find. If they all check good, see if it will start for a couple seconds using starting fluid.
Oct 19, 2018 at 7:59 PM
