Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Mercury
Grand Marquis
Trouble Codes
OBD1 Codes
Code 14
OBD codes 14 and 34, Engine turns over fine, but not a hint of firing?
1989 MERCURY GRAND MARQUIS
100,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
SDPLASKO
MEMBER
FOLLOW
Engine turns over fine, but not a hint of firing. OBD codes 14 and 34.
May 23, 2023 at 9:44 AM
CERTIFIED EXPERT
I would replace the MAF and coolant sensors here is what is said about the codes:
OBD Code 14: This code indicates a problem with the Engine Coolant Temperature (ECT) sensor or circuit.
OBD Code 34: This code indicates a problem with the Mass Air Flow (MAF) sensor or circuit.
May 23, 2023 at 1:45 PM
SDPLASKO
MEMBER
Thanks for your input. I will update you with the results.
May 24, 2023 at 12:25 AM
CERTIFIED EXPERT
Thank you.
May 25, 2023 at 4:59 PM
