Thanks for the additional information. Next step would be to verify voltage at the pink wire going to the ignition coil. it should have around 10-12 volts with key on and while cranking.
if it does the next step is to use an led test light like the one below and see if it flashes while cranking and with the tip on the white and black wire at the coil.
https://www.amazon.com/OTC-3631-Heavy-Duty-Logic-Tester/dp/B001GZH1C8
It's mandatory to use this type of test light not to damage the computer system. it'll flash ground while cranking if the coil is getting signal.
Now if both test fail then the next step it to replace the crankshaft position sensor. it's located on the timing cover. i'll post how to replace it below.
CRANKSHAFT POSITION (CKP) SENSOR REPLACEMENT
REMOVAL PROCEDURE
IMPORTANT: The CKP System Variation Learn Procedure will need to be performed whenever the crankshaft position (CKP) sensor is removed or replaced. Refer to CKP System Variation Learn Procedure.
1. Raise the vehicle. Refer to Lifting and Jacking the Vehicle.
2. If the vehicle is equipped with the underbody shield package, then remove the steering linkage shield mounting bolts.
3. Remove the steering linkage shield.
i
4. Disconnect the CKP sensor harness connector.
5. Remove the CKP sensor mounting bolt.
6. Remove the CKP sensor.
INSTALLATION PROCEDURE
IMPORTANT:
^ When installing the CKP sensor, make sure the sensor is fully seated before tightening the mounting bolt. A poorly seated CKP sensor may perform erratically and may set false DTCs.
^ Do not reuse the original O-ring.
1. Replace the CKP sensor O-ring.
2. Lubricate the O-ring with clean engine oil before installing the CKP sensor.
IMPORTANT: Make sure the CKP sensor mounting surface is clean and free of burrs.
3. Install the CKP sensor.
NOTE: Refer to Fastener Notice in Service Precautions.
4. install the CKP sensor mounting bolt.
Tighten
Tighten the CKP sensor mounting bolt to 8 N.m (71 lb in).
5. Connect the CKP sensor harness connector.
6. Install the steering linkage shield.
7. Install the steering linkage shield mounting bolts.
Tighten
Tighten the bolts to 33 N.m (24 lb ft).
8. Lower the Vehicle.
9. Perform the CKP System Variation Learn Procedure. Refer to CKP System Variation Learn Procedure.
The relearn procedure must be done with a high end scan tool most shops will have. The vehicle will set a code if the relearn is not performed.
Jan 18, 2019 at 10:51 PM
